Home > Show Us Yours! > Turn up the volume and enjoy..SC Sprint TwinKam on engine dyno
John, DO you think it would be the same on the road, when bolted into an engine bay, just thinking the cars suspension and flex might effect it?
On 26th Nov, 2009 johnK said:
Gr4h4m - well spotted -that fan belt is tensioned correctly as well- the interesting thing - well for me - was the way the reasonance of thebelt moved from the "front" run to the "back" run and then back again between 6000/6500/7000/7500. you see all sorts of things on an engine dyno rather than on the rollers where everything is flapping about!
JK
johnK
Member #: 690
Norfolk
In reality the only difference here is the engine is bolted solid to the dyno bed with a rubber coupling driving the "flywheel" - there is potential for a lot more vibration through the mounting points on an engne dyno than in a car, both from the engine and the dyno. On the rollers you don't see this belt excitment.
JK
If Carling made Mini engines
On 27th Nov, 2009 fastcarl said:
On 27th Nov, 2009 Jimster said:
hows the twink turbo coming along john?
good question,
I love the way you ignored this John lol
Paul
good question,
Paul
he's a class act,lol rumour has it he was a politician in a previous life,
carl
johnK
Member #: 690
Norfolk
I don't know what you mean, if it relates to the topic its worthy of an answer, simple really?
JK
I still think youre scared of it John
Paul
johnK
Member #: 690
Norfolk
I hope not fella!
Users viewing this thread: none. <- Prev
