| Home > A-Series EFI / Injection > Interest in built MS-based ECU | |||||||
8th Dec, 2009 at 06:24:34pm
On 8th Dec, 2009 Paul S said:
I'm sure your comments are valid Rod. But this thread has turned into another that will put people off because it comes across as too techy. The whole point of Jean's proposal is to make it simpler to implement so that the user does not have to worry about processors, drivers, Vr or opto circuits. I'm fully supportive. I want one for that car I don't own yet, but also have my eye on some wheels for it. Point taken Paul but unfortunately the whole subject is "techy". From all the months you have spent on getting the code to run as it should, I would hate to think that anyone could read this and think they could just buy the version Jean proposes and expect it to work "out of the box". My only queries were on the hardware and Jean has answered most of them so I am 100% supportive now. Maybe I should have done the "techy" queries by PM rather than on the forum but I have already said that getting rid of all the add-on boards and not having to build it yourself makes it a good way forward. But I wouldn't want anyone to think they could just buy it, plug it in, and it works straight away... Hence our debate (off the forum) about what to put in the build manual about setting up a basic MS2. Schrödinger's cat - so which one am I ??? |
8th Dec, 2009 at 06:26:42pm
Rod,
8th Dec, 2009 at 06:33:51pm
I should add that I agree with Rod that no one should expect this to be a plug and play project. There will still be some decisions to be made on the fueling components and a fair amount of tuning with the pre-requisite understanding of what everything means.
8th Dec, 2009 at 07:03:32pm
OK,
3 Posts Member #: 7068 Junior Member Flitwick, Beds |
8th Dec, 2009 at 07:45:07pm
Hi Jean
8th Dec, 2009 at 07:52:46pm
Hi Jean
9th Dec, 2009 at 04:39:23pm
I think that it is worth emphasising that the Siamese Code is now part proven, at least on my car.
10th Dec, 2009 at 01:41:59am
that .94 lump at 5000rpm was when the bleed valve primed ,so it got a boost spike ,its better on a level boost ..
10th Dec, 2009 at 04:14:42am
On 10th Dec, 2009 robert said:
id like to find a simple ecu that would just drive one inj i could put in the inlet pipe and a simple boost/ rpm based controller and kick it in at higher boost . A basic MS1 setup will do that and I doubt you'd find something cheaper, especially if you go with a V2.2 board. However, I think it's a kludge and you still won't know what the AFR difference is between the inner and outer cylinders. And you won't be able to correct it with such a setup either. Jean |
10th Dec, 2009 at 11:51:19am
I'd be interested in this Team www.sheepspeed.com Racing
10th Dec, 2009 at 04:29:52pm
id like to find a simple ecu that would just drive one inj i could put in the inlet pipe and a simple boost/ rpm based controller and kick it in at higher boost . A basic MS1 setup will do that and I doubt you'd find something cheaper, especially if you go with a V2.2 board. However, I think it's a kludge and you still won't know what the AFR difference is between the inner and outer cylinders. And you won't be able to correct it with such a setup either. Jean absolutely agree jean . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
21st Jun, 2011 at 01:42:25am
Even though this was started a long time ago, I have finally decided to go ahead with the development of a configuration that might be of interest to some people here: http://forum.jbperf.com/viewtopic.php?f=14&t=776.
95 Posts Member #: 9314 Advanced Member Chippenham, Wilts |
21st Jun, 2011 at 08:33:09am
As an aside, how about a new metric sized main board to replace the V3, incorporating your 4 channel driver board, dual O2 etc, as we use very little of the V3 board anyway with an industry standard plug like this
21st Jun, 2011 at 03:02:27pm
On 21st Jun, 2011 Ratty said:
As an aside, how about a new metric sized main board to replace the V3, incorporating your 4 channel driver board, dual O2 etc, as we use very little of the V3 board anyway with an industry standard plug like this http://www.polevolt.co.uk/acatalog/info_ECU36_PCB.html That would go against the MegaSquirt license. The only allowed ways of making your own MegaSquirt-based ECU is to use the MicroSquirt module (as planned here) or get a licensing agreement (which is not necessarily an easy or cheap task). Jean |
12th Aug, 2011 at 07:46:39pm
I have made significant progress on this and I have posted the details here: http://forum.jbperf.com/viewtopic.php?f=14...76&p=3503#p3503.
30th Sep, 2011 at 11:04:08pm
I have almost everything so I should have the first running unit soon. Here are a few pictures of the board, module and enclosure. The board is not fully assembled yet and the module is there for trial fitting.
30th Sep, 2011 at 11:20:35pm
Looks neat I run a supercharger and I don't care the TB is on the wrong side.
1st Oct, 2011 at 09:35:28am
Good work, Jean. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
54 Posts Member #: 64 Advanced Member |
14th Oct, 2011 at 09:14:57am
Any new info on price? |
14th Oct, 2011 at 04:10:28pm
Actually, I just found out that I need to redesign the power supply. Under normal circumstances the current supply is fine but if there is more load on the Vref output, it becomes a bit marginal. So I'd rather make the change instead of telling people to strictly limit what they connect to Vref. There will still be a limit but there will be some margin.
18th Oct, 2011 at 09:18:52pm
When do you expect it to be ready? |
18th Oct, 2011 at 09:41:28pm
I would say about a month or so. I need to finish the new layout (just the power supply section) and have the new boards made. Then assemble one to test and check everything is ok.
19th Oct, 2011 at 08:51:08am
Looking very good, deffinately want one of these to finish off my car |
20th Oct, 2011 at 10:27:00am
I second that... |
22nd Nov, 2011 at 12:49:11am
Well, I have the first batch of boards and those who had shown interest here either have not responded to my PMs or are not yet ready to buy a unit.
