| Home > General Chat > cowling mod, worth wile? | |||||||
5th Jan, 2010 at 05:34:03pm
Afternoon lads, I have been out today and progressed from cardboard to aluminium. I am pleased with the results of my fabrication and it just needs a bit more adjusting and cleaning up. The pictures show it as it is tonight in its raw state. My new Kenlowe fan arrived as well so it will be a busy day of fitting tomorrow.
5th Jan, 2010 at 05:40:30pm
Man, you dont hang around! |
5th Jan, 2010 at 06:39:47pm
do you recon a louvre(s) 1/2 way down will help flow in. I was just thinking the size of the gap might hinder the draw on the fan when stood still? I run a supercharger and I don't care the TB is on the wrong side.
5th Jan, 2010 at 06:42:44pm
I might help to break it into 2-3 sections, a bit like a rear difuser,
5th Jan, 2010 at 06:51:45pm
Nice piece of fabrication work :)
On 19th Jan, 2010 wil_h said:
5th Jan, 2010 at 07:23:43pm
I was going for the rigidity of the aluminium not the lightness of it. And its not much more in weight. The heavy stuff is at the sides to hold the rad on. I have started posting on Instagram also my name on there is turbomk1golf
5th Jan, 2010 at 08:06:56pm
stick the fan directly to the rad with sikaflex |
5th Jan, 2010 at 08:25:00pm
i will be mounting it as close to the rad as i can get it i am cutting the wing out so the fan sits in to the rad I have started posting on Instagram also my name on there is turbomk1golf
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
5th Jan, 2010 at 08:44:57pm
I red somewhere (and ther was Vizrad nome on it) that the mechanical fan is only useful at low speed.
Edited by Advantage on 5th Jan, 2010. Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
5th Jan, 2010 at 08:58:40pm
yes i was reading that last night but fans have come on a long way now I have started posting on Instagram also my name on there is turbomk1golf
5th Jan, 2010 at 11:07:06pm
That's the way to do it if retaining the side rad. Good work! On 13th Jul, 2012 Ben H said:
5th Jan, 2010 at 11:14:38pm
meaning they are now better than in the 80's ?
Rusty by nature
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
5th Jan, 2010 at 11:18:16pm
looks really good ! On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
5th Jan, 2010 at 11:22:09pm
looks very nice! Would it be worth flaring the edges facing the road? so you get a funneling affect, can see it being tricky to close the gaps up in the 2 corners that you would have to cut, i reckon it would be worthwhile? May have a bit of a ramming affect as well to maybe increase density? just guessing hear.... |
5th Jan, 2010 at 11:26:39pm
i would have thought thats the way to do it,
5th Jan, 2010 at 11:29:58pm
Hi Advantage I know it will draw alot of power, I don't dispute that. It's not a given that it will work at the minute as I have not seen it done before. If it doesn't work too well during the testing stage I can always put it back the way it was. If you don't experiment then you never fnd these things out I guess. I have started posting on Instagram also my name on there is turbomk1golf
5th Jan, 2010 at 11:35:52pm
5th Jan, 2010 at 11:58:02pm
On 5th Jan, 2010 Advantage said:
Still, if the mouth of your rad setup can be made any bigger (as in there is room for it) it will be better, won't it ? im quite sure the rule is teh aperature for teh radiator must be ~1/3 the surface area of the radiator for best effect, any larger and the core becomes a restriction(so the whoel lot will flow less) any less and the mouth becomes the restriction. however i cant remember in the slightest where i read that.
6th Jan, 2010 at 12:00:12am
Ive read similar to that too, but i cant remember where |
6th Jan, 2010 at 02:04:48am
corky dufus bell lol?
6th Jan, 2010 at 09:26:59am
What I'm planning to do is have the radiator on a automatic switch, so the fan only comes on when the engine is getting hot. That way its not drawing power when it doesn't need too.
6th Jan, 2010 at 09:47:28am
6th Jan, 2010 at 07:57:10pm
I would say go on and experiment.
Rusty by nature
6th Jan, 2010 at 09:35:40pm
Hi lads well today has been spent on the phone and a bit of work done outside. After i got through the 40cm of snow on the car, I got the wing cut out. It doesn't look to nice at the mo, I got the wiring kit for the fan today and i have ordered a new electrical pump today and I have also ordered a water pump blanking plate from Dave at kad. He is going to make it 19mm for me to match the pump. I made the brackets for the fan to mount it to the wing as well. Not a bad days work
Edited by madmk1 on 7th Jun, 2016. I have started posting on Instagram also my name on there is turbomk1golf
![]() 112 Posts Member #: 2011 Advanced Member Ashington, West sussex |
6th Jan, 2010 at 11:03:29pm
just a idea that came to mind.
