| Home > General Chat > SC 7 Port Billet Head - Pics | |||||||
1425 Posts Member #: 690 Post Whore Norfolk |
21st Jan, 2010 at 08:39:59pm
Anodising - we'll see! Joe yes my thoughts on the chambers are similar - the chambers can be made very big if required for forced induction
If Carling made Mini engines
21st Jan, 2010 at 08:49:51pm
When will we get flow bench figures? I seriously doubt it! |
21st Jan, 2010 at 08:51:51pm
or see a sectioned one PMSL On 28th Aug, 2011 Kean said:
21st Jan, 2010 at 08:53:38pm
On 21st Jan, 2010 mini13 said:
or see a sectioned one PMSL could the 3d drawing be sectioned to give a rough idea? Yes i moved to the darkside |
21st Jan, 2010 at 09:02:17pm
flow bench figures will follow after the engine dyno - We need to give it some grief to see what it does - expect some youtube vids!
![]() 497 Posts Member #: 7641 Senior Member Jersey, CI |
21st Jan, 2010 at 09:24:02pm
Wow |
21st Jan, 2010 at 09:25:23pm
On 21st Jan, 2010 johnK said:
anyone is free to come over and sit at my cad station to look inside the head as much as they want!! i think its worth a trip out tbh but seing as your going bingley ill just see it there edit ok so i just googled your postcode ypur further than i thought
Edited by Brett on 21st Jan, 2010. Yes i moved to the darkside |
122 Posts Member #: 2023 Advanced Member nr Portsmouth ,Hampshire |
21st Jan, 2010 at 10:27:06pm
will it be sold with the big ports shown or a smaller version ? |
22nd Jan, 2010 at 09:32:17am
We'll see how the testing goes and then make a final decision on exh port sizing - inlets will always be 36mm dia.
22nd Jan, 2010 at 09:37:38am
Why haven't you chosen to make the inlets downdraught like the early Weslake cross flow?
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
22nd Jan, 2010 at 12:45:41pm
Ah John,,, im very dissappointed,,, a cam ontop would have been far far better & probably much easier too,,, what`s with you these days mate??? going backwards in your old age ???
www.miniman.com.au
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
22nd Jan, 2010 at 01:10:15pm
OHC would require a specific cam or some rockers as the lifts on standart cams are done to work with a 1,25 ratio.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
22nd Jan, 2010 at 01:15:40pm
yeah but a it doesnt cost 500million dollars/pounds to make a cam to suit
Edited by MadMatt on 22nd Jan, 2010. www.miniman.com.au
22nd Jan, 2010 at 01:47:27pm
I positively hate the idea of an overhead cam. I believe the remit of this project was for a simple cheapish solution to getting rid of the 5 port problem and improving performance. An overhead cam totally goes away from this. As I have already stated the simplicity of the 7 port crossflow head is the important factor here. More power with other heads will be possible, but nowhere near as elegant. http://www.twin-turbo.co.uk
22nd Jan, 2010 at 02:12:47pm
Hi Matt - thanks for the comments - loving the vids of the crazy R1 powered car!, I have to say that at no way along the process was an OHC option looked at! Ben H summed up 100% the project brief. I'll keep the K as the SC OHC projects!
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
22nd Jan, 2010 at 02:15:45pm
How would these fit a 998? Or will it be the same as fitting a stock 1275 head? In boost we trust |
22nd Jan, 2010 at 02:27:35pm
On 22nd Jan, 2010 best_stig said:
How would these fit a 998? Or will it be the same as fitting a stock 1275 head? I'd imagine yes, the same block pocketing would apply as fitting any other 1275 head on a small bore block. JF. On 21st Jan, 2011 fastcarl said:
22nd Jan, 2010 at 02:30:14pm
Alloy 7 porters are all the rage.
22nd Jan, 2010 at 02:34:06pm
On 22nd Jan, 2010 Paul S said:
Alloy 7 porters are all the rage. I've been to Liecester this morning and was presented with a very tidy example, although cast. 5 Porters rule still for me. Ive seen the cast one this morning too, I have pictures. 5 port for me too unless a 7 port only cost a quid, though Im very interested in it. I still want to see the car its going in. Paul Edited by paul wiginton on 22nd Jan, 2010. I seriously doubt it! |
22nd Jan, 2010 at 02:35:59pm
Alloy 7 porters are all the rage. I've been to Liecester this morning and was presented with a very tidy example, although cast. 5 Porters rule still for me. Ive seen the cast one this morning too, I have pictures. 5 port for me too unless a 7 port only cost a quid Paul Mr Whitton managed to extract large amounts of cash from me this morning. Alloy 5 port on order. Must have just missed you. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
22nd Jan, 2010 at 02:38:50pm
I wasnt there Paul, just been chatting with Steve and he sent me the pics I seriously doubt it! |
22nd Jan, 2010 at 02:40:44pm
Maybe this will drop the cost of the old iron version. They must has serious margin in them by now.. I run a supercharger and I don't care the TB is on the wrong side.
23rd Jan, 2010 at 04:40:10am
no worries John, i totally understand all that , appreciate & respect it fully.
www.miniman.com.au
784 Posts Member #: 912 Post Whore North Yorkshire |
23rd Jan, 2010 at 07:44:28am
I have to say John that’s 1st class.
Edited by Si P on 23rd Jan, 2010. I drill holes in everything..! |
![]() 568 Posts Member #: 1200 Post Whore Bristol |
24th Jan, 2010 at 08:07:10pm
Well done john, very nice indeed, will have a close inspection at the show next weekend, I also had a look at your new throttle bodies for the K head at the autosport show, looks like my credit card detals will be on there way to you later in the year! :) |
Top work, that looks amazing.
