| Home > Technical Chat > ignition map | |||||||
12th Feb, 2005 at 08:50:18am
On 11/02/2005 23:19:06 TurboDave said:
I dare say there is a big market for someone who offers to map MJ / MS stuff over in england............. So there is Dave
AlexF |
13th Feb, 2005 at 03:57:37pm
oh, you buying a dyno now? On 17th Nov, 2014 Tom Fenton said:
13th Feb, 2005 at 04:59:40pm
Just some time...
AlexF |
14th Feb, 2005 at 09:08:29am
Dave,
http://www.twin-turbo.co.uk
![]() 36 Posts Member #: 262 Member Netherlands |
26th Feb, 2005 at 09:37:10am
Hi there,
Op de bank beleef je geen avonturen |
26th Feb, 2005 at 09:10:28pm
Ok Alex sorry it took so long to find...
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
26th Feb, 2005 at 10:21:38pm
Thanks for the map.
28th Feb, 2005 at 12:32:53pm
It looks like we will have the hilclimber on the rollers before the start of the season. so after the session I will post the map that we create. I know it is quite different from most of the turbo engines on here, but it should be close enough for a start.
23rd Mar, 2005 at 11:27:53am
OK here is the map for all who are interested. I would not say it is a great map for a road car, because we did not waste time making the map work for crusing conditions and that is all just a guess. The important points are between 2000rpm and 4000rpm where the car comes on boost. We concentrated around here while tuning and got good results, with the boost comming in much quicker. Obviously this is for 998cc so i don't know where boost starts to build on any other engines. The 14s that you see all over the lower rpm bins are an attempt at some idle control this is yet to be fully sorted. I would expect also that the advance could be increased under cruse conditions, but this is quite easy to do driving around with a laptop. Anyway the map.
Edited by Ben H on 23rd Mar, 2005. http://www.twin-turbo.co.uk
23rd Mar, 2005 at 12:36:19pm
thanks ben!
AlexF |
1171 Posts Member #: 107 Post Whore Sunny Sussex |
23rd Mar, 2005 at 07:03:33pm
ben, what software is that? MegaTune?
24th Mar, 2005 at 07:59:08am
Hi Ben,
24th Mar, 2005 at 08:20:38am
The ignition system is Megasquirt & EDIS, running the Extra code. The extra code has lots of features, but I am using it because of the 12x12 map.
24th Mar, 2005 at 09:01:58am
Popeye, CR = 7.3:1, Intercooled - Yes
24th Mar, 2005 at 09:29:37am
hot days???
AlexF |
24th Mar, 2005 at 09:46:56am
On 24/03/2005 08:20:38 Ben H said:
The ignition system is Megasquirt & EDIS, running the Extra code. The extra code has lots of features, but I am using it because of the 12x12 map. wheres the extra code? The standard MS software has quite a limited table. :( /edit - Aha found it. Gonna grab me one of those daughterboards too. Edited by Mike on 24th Mar, 2005.
24th Mar, 2005 at 09:52:37am
Deffo hot days.
24th Mar, 2005 at 09:53:50am
As far as I understand it the hotter the inlet air temperature the more likely it is you will get detonation. That is one reason why you need an intercooler to run more boost. So if the inlet air temp increases to much the ignition should be retarded
24th Mar, 2005 at 10:57:44am
Cold air is denser... so you run an intercooler to take out the heat the turbocharger has added to the air. Typically the more boost you get from a turbo the more heat it produces... its all in the efficency of the turbo and what part of the compressor map you are running in.
AlexF |
24th Mar, 2005 at 01:41:14pm
I never thought of it like that before. I guess that is why production cars tend to have intercoolers that are bypassed when it is cold.
24th Mar, 2005 at 01:45:58pm
It does make sense, its the reason why most fuel injected stuff feels faster (well, IS faster) on a crisp cold morning, and also the same reason that my turbo diesel produces more boost in the cold conditions than it normally will on a hot day etc.
24th Mar, 2005 at 01:48:46pm
Just found out...
AlexF |
24th Mar, 2005 at 01:53:26pm
The Ford RS Turbo has a map?!
24th Mar, 2005 at 02:31:39pm
Have you ever measured you inlet temperature while on boost? I would say 70c is quite attainable. On a friends N/A imp we got nearly well into the 30's just driving around. I am pretty sure we have measured 60c before the intercooler when we were running much less boost.
24th Mar, 2005 at 07:17:59pm
when I get my act together I am going to measure the temp at every point round and in my engine :)
AlexF |
