Home > Technical Chat > Mitsubishi Turbochargers
or here, possibly a little out of date now but still usefull
best_stig
Member #: 6449
Brisbane, Australia
What about a TF035? Pretty similar size and the starlet guys over here usually run those.
In boost we trust
Found some useful data that I have not seen before on the Owens Developments site:
http://www.owendevelopments.co.uk/MHIperfo...hargersList.pdf
mcalvert39
Member #: 442
Manchester
Its funny that mitsubishi do an upgrade turbo for the subrau.
there is not a massive choice when it comes to turbo's, subaru have to buy there turbo's from somewhere makes sense to buy them in from your own country
What's funny ?
Mitsubishi and Subaru ( Or Fuji Heavy Industries ) make many things for many markets. Not just cars.
And Subaru have had Mitsi turbochargers for around 20 years. Certainly nothing new.
And worth baring in mind if looking at Evo turbochargers. Most of them rotate the opposite way.
Edited by stevieturbo on 17th Oct, 2011.
i think thats only the ones that go south of the equator steve .
fredski
Member #: 9558
Netherlands
I'm quite new in the turbo field and reading these topics with great interest..
found this on ebay :
www.ebay.co.uk/itm/Genuine-VOLVO-S40-V40-Turbo-TD04L-12T-8-5-49377-06250-/110560400567?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item19bde9d4b7
I have not seen this setup before...is that an internal blow off valve returning to compressor intake?
could this make a good turbo for a road going 1380?
Thanks
Fred
Ooooo twin scroll. What a find :)
The TD04L-12T should be good for 200hp it says in the blurb I posted yesterday.
EDIT: Good write up on twin scroll:
http://www.modified.com/tech/modp-0906-twi...gn/viewall.html
Also talks a lot about exhaust manifold design and pulse tuning.
Edited by Paul S on 17th Oct, 2011.
Many of the Volvo's from later model 940 turbo's use Mitsi TD04 based units, but with a T25 style flange.
Seems a lot of the later fwd use similar units too, although maybe rated at higher power.
And @ Robert
All Mitsubishi Evo's from around Ev05 onwards, the turbocharger rotates anti-clockwise. with the scroll etc opening the opposite way to the more conventional CW rotation units everyone else uses.
Why they do this Ive no idea
the one on my ovlov is i believe a TD04 19T with a t2 sort of style flange ( maybe t25? dunno not seen a t25 turbo to hand)
fredski, the internal re-circ thing can be blocked and ive seen kits from volvo tuners to block the standard re-circ valve and replace with an atmospheric bov
Edited by Brett on 17th Oct, 2011.
AFAIK there is no separate T2/T25/T etc
There is the T3 flange, then the other units carry a smaller flange.
So T2, T25, T28 etc are all the same. Unless there is an odd OEM flange thrown in somewhere
DVSMNI
Member #: 3668
NEW ZEALAND - moving to Australia
the td04 is off a mitsubishi gsr, this has the 4g93T engine which is a 1800cc, the turbos are small most people throw them away here in nz and upgrade to the td05 20G, the turbos are good an people do 15psi + threw them.
1966 MK1 1034CC TURBO MINI
DVSMNI
Member #: 3668
also these cars were first produced in 1992, they come out in the same shaped car as evolution 123 shape lancer.
Users viewing this thread: none. <- Prev
