Home > Technical Chat > MINISPARES MOLYBDENUM CROSS PIN DIFF
A Quaife ATB would be better. But for over £500 it's expensive for a 105hp engine.
x-pin diff all the way, although if i had £500 to spend......
Have you checked that everything is well with your suspension? Nic found out that poorly fitted ball joints can cause issue *hehe!*
It sounds like there could be a problem at the front left corner, which is exagerating the torque steer problems.
Ozyris
Member #: 9054
Disneyland Near Paris
the old engine is already undo for makeing a new one my balljoint are new... it's not like if i will lost 500£ it's for later like we said in french "se qui est fait n'est plus a faire" si'm think it's a good invest but maybe i have a problem in my geometry i will see again on the laser geometry said =)
Advantage
Member #: 1450
Near Paris - France
The problem is not the way to check the geometry, it is the numbers you tell the guy to set your geometry to ...
Honnestly I did search on that particular topic but there is no simple answer as it has to do with people likings ...
Rusty by nature
Ozyris
Member #: 9054
i have a fast road configuration i have wrote it somewhere in my last computer but i have lost it with my last hard drive failure.... :(
but i'm agree with you advantage so i will see i have two month for know the next investment for my new engine... =)
Users viewing this thread: none. (+ 4 Guests) <- Prev
