| Home > Help Needed / General Tech Chat > sticking starter motor/solenoid faulty? *update 10/08/11 all sorted. | |||||||
9th Jan, 2011 at 04:55:27pm
Have you checked fuel pressure?
9th Jan, 2011 at 07:32:59pm
No not checked, how would I go about doing that? Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
388 Posts Member #: 442 Senior Member Manchester |
10th Jan, 2011 at 06:38:51pm
Id try changing the points and condenser. Can cause bogging when under load. Thats if your still using points.
10th Jan, 2011 at 07:50:59pm
No blockage going to the carb, not sure about return, will give points a try, cheers Audi s4 b5 - 470bhp & 486ft lbs
8th Aug, 2011 at 08:01:26am
So this has just started again after the engine has been out and had a new loom fitted, it was turning over fine for ages then just started happening. Last time I took it off the road to do some work and when I came to use it again it was turning over bang on as it should, took it off the road again this time, was turning over fine then just started again, it seems to turn over quickly for about half a second then its as if something is jamming, it just stops then starts again straight away and keeps doing this, it may well be my battery as it took a lot of hammer but I very much doubt it, ill stick it on charge tonight and see what happens, if not I'm going to try a new battery cable. Audi s4 b5 - 470bhp & 486ft lbs
8th Aug, 2011 at 08:08:35am
Just don't use the rest of cable from the lawnmower On 11th Feb, 2015 robert said:
8th Aug, 2011 at 08:28:30am
No andy iive ran out I used some more to wire up my gauges... Just kidding, although my personal top sparky is coming tonight to do a bit for me, he may be reaching for the cable again haha Audi s4 b5 - 470bhp & 486ft lbs
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
8th Aug, 2011 at 04:28:41pm
have you tryed a different startermotor? my starter died on saterday just after its mot was turning over fine but got slower and slower as if i had a flat battery but the charger said it was full tryed different starter and was fine. Done now needs redoing lol |
8th Aug, 2011 at 05:30:38pm
starter motor was new end of last year, should be ok. Audi s4 b5 - 470bhp & 486ft lbs
8th Aug, 2011 at 05:36:42pm
Have you replaced the main battery cable? On 26th Oct, 2004 TurboDave16v said:
8th Aug, 2011 at 05:46:27pm
no i have not that is next on my list, tom suggested this a while back when it was happening before, but i took the car off the road for for a while, came to use it 2 months later and it was fine so never bothered to change it. Audi s4 b5 - 470bhp & 486ft lbs
10th Aug, 2011 at 10:13:28am
Non of this could be caused by the intercooler touching the ht leads? Thinking about it the first time it happened was the first time I used it after the intercooler was fitted? It has worked previously with the ic fitted though so I doubt that.
10th Aug, 2011 at 11:04:45am
sorry if this has come up already as i've not read the whole message but check the earth straps; i had a similar issue years ago and changed the engine to body strap and solved it |
10th Aug, 2011 at 11:31:56am
Rob it has been mentioned before and I have cleaned it up along with the engine and inner wing with a wire brush, but had no effect, I could try a new one though, mine currently goes to the inner wing but I've seen a few that go along the top engine steady, is this a better plate to put it or is there no difference? Audi s4 b5 - 470bhp & 486ft lbs
10th Aug, 2011 at 11:37:28am
i've always fitted one to the same fixings as the upper engine steady.
10th Aug, 2011 at 11:55:57am
I shall get a new earth strap then and fit it to the engine steady as above, also battery was fully charged and has always been a very good battery but I've put it on charge again last night to make sure.
10th Aug, 2011 at 12:28:14pm
i'd look at the timing first then - as its been adjusted since last run. Even try getting someone to turn the key and move the dizzy around, you'll notice the difference in how the engine turns over |
10th Aug, 2011 at 12:42:59pm
Ill give it a shot tonight, cheers. Audi s4 b5 - 470bhp & 486ft lbs
10th Aug, 2011 at 07:59:14pm
heres a quick vid, with fully charged battery, any ideas? will have a play with timing tonight and order new battery cable and earth strap tomorrow.
10th Aug, 2011 at 08:02:03pm
try plying with the timing a little before you spend any more cash |
10th Aug, 2011 at 08:07:14pm
rob you genuis lol , rotated the dizzy a little, tried it and turned over a little better, rotated it a bit more, even better, kept rotatiing it a little and bingo, turns over fine, but i am now getting a little puff of what smells like fuel every now and again through the plenum, fuel pressure diaphram split? Audi s4 b5 - 470bhp & 486ft lbs
10th Aug, 2011 at 08:09:14pm
its all down to the timing; get it set correctly and you should be fine |
11th Aug, 2011 at 07:01:16am
I checked the diaphram and it all looks ok, when I was at bogg brothers rolling road dave did say he thought my FPR didn't seem to be rising with boost, now there's what seems to be puffs of fuel vapour or something puiffing out of my plenum with the intercooler off, every half a second or so, I'm about to order a new FPR and I ordered a gauge too. Audi s4 b5 - 470bhp & 486ft lbs
