| Home > General Chat > Diesel Car on Veg Oil | |||||||
547 Posts Member #: 2928 Post Whore peterborough |
18th Jan, 2011 at 10:32:45pm
On 18th Jan, 2011 MikeRace said:
Ive been told to run it 70/30 split in winter and 80/20 in summer. I suppose if you dont mind using used oil and straining it then go for it. This is perfect, that's how I used to run my old astra, the Isuzi engine 1.7 tweak the pump slightly and fitted a bleed valve, the thing flew, literally in the end with a little help of a hy-ab, robbed from outside my garage Jack Jones |
19th Jan, 2011 at 09:32:40am
this has made me think about running the audi on this stuff. I'll need to look into it |
19th Jan, 2011 at 09:38:02am
I considered it Rob on my old one, but with an injection pump costing about £1800 I decided against it.
19th Jan, 2011 at 09:50:26am
thats my worry - the pump hasn't given me any issues yet and, with the mileage on it now, I don't really want to temp fate (having said that my local guy recons I'd be closer to £800 for a replacement pump).
19th Jan, 2011 at 10:02:15am
an old 405/406 estate with a 1.9td 90bhp engine would be pretty cheap to run like this On 11th Feb, 2015 robert said:
19th Jan, 2011 at 11:51:14am
I was thinking of an old passat -keep it in the VAG family |
19th Jan, 2011 at 11:54:11am
I was thinking of this the other day, get something like a Bora TDI 90, then "Bluemotion" it yourself- skinny low rolling resistance tyres, undertray, lose some weight out of it etc.
19th Jan, 2011 at 11:58:34am
The bluemotion thing definately works my golf see's over 60mpg on a regular basis where as the non bluemotions we have are low to mid 50's If something is worth doing, it's worth doing half of. |
19th Jan, 2011 at 01:57:01pm
if I could get even 40mpg i'd be a lot happier - works out on the back of the fag packet at a tank a month saving over what i get now |
19th Jan, 2011 at 02:08:10pm
Old Isuzu engined vauxhalls are supposed to be pretty bomb proof on veggie oil. If something is worth doing, it's worth doing half of. |
19th Jan, 2011 at 02:18:55pm
that would mean driving a vauxhall though! |
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
19th Jan, 2011 at 03:07:11pm
I did it for a short while (Merc W125 250)... But decided it's not worth it for the few pennys saved. As a minimum conversion I drove a SVO/diesel mix. This winter cold start were OK with ~50% diesel.
Edited by Asphalt on 19th Jan, 2011. [X] nail here for new monitor |
19th Jan, 2011 at 05:47:46pm
just been looking into this a bit more and running a second car is out of the question. Insurance quote for a mk3 golf diesel was nearly £500 for the year as i'd keep the NCB on the audi.
19th Jan, 2011 at 06:06:47pm
Rob ring around, I got the Shogun insured for £350 fully comp as they mirrored the NCB off my main policy which is still running on my Audi.
19th Jan, 2011 at 07:39:01pm
I'll maybe try that.
![]() 489 Posts Member #: 9159 Senior Member Devon |
19th Jan, 2011 at 08:08:45pm
19th Jan, 2011 at 08:22:15pm
interesting reading - i'm no tecie - does anyone have an opinion on this system?
On 19th Jan, 2011 jamestar said:
http://www.hydrogenhybrids.uk.com/index.html |
19th Jan, 2011 at 09:58:43pm
On 19th Jan, 2011 Rob Gavin said:
interesting reading - i'm no tecie - does anyone have an opinion on this system? On 19th Jan, 2011 jamestar said: http://www.hydrogenhybrids.uk.com/index.html did a mamouth amount of research on these a while back, to get enough hydrogen through electrolysis (essentially what this is) to make any difference to the mpg of the average car required 50A+ of current, this came out the alternator, which is driven by the engine. so from a simple physics point of view of you have: an engine, which isnt 100% efficient(loosing power through heat etc) supplying power to an alternator which isnt 100% efficient(loosing power through heat etc) supplying a 2v/cell electrolysis tank, which isnt 100% efficient (loosing power through heat etc) thats alot of losses to even break even on the meagre hydrogen production. those cells at 1A have no chance. however, there is a theory, that with the correct pulsed signal a hydrogen electrolysis cell will yeild far greater hydrogen+oxygen than normal, making the system workable, but its just a theory, and despite a few "gurus" claimign to have done just this, i couldnt find any actual hard proof that wasnt "destroyed by the petrol companies". :) turbo 16v k-series 11.9@118.9 :)
20th Jan, 2011 at 08:50:53am
Dennis has said it.
20th Jan, 2011 at 09:34:50am
And that's the point: hydrogen is no energy source. It's just a carrier (the way we can use it that is).
20th Jan, 2011 at 09:43:42am
thanks guys - I had my concerns it was a bit hyped up to be true |
20th Jan, 2011 at 11:28:43am
Nuclear powered cars are the way foward!!! 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
20th Jan, 2011 at 11:57:21am
On 20th Jan, 2011 MikeRace said:
Nuclear powered cars are the way foward!!! It's pronounced nu-cu-lar!
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
20th Jan, 2011 at 09:35:17pm
I think huge fuel economy needs a specific vehicle.
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
207 Posts Member #: 193 Senior Member Aylesbury |
20th Jan, 2011 at 10:44:16pm
Thanks for all the posts, after reading them i have gone for it. I am running a 20% fresh veg oil - 80% diesel at the moment while the weather is cold. Will change the ratio once it warms up.
