Home > Help Needed / General Tech Chat > Timing case breather, Any Ideas. Please
t@z
Member #: 452
Chester, UK
isnt that a pain in the ass. i see some ppls but they look a reet bugger to fit!
www.twitter.com/lilpinkiy
bennyy
Member #: 9037
Doncaster, yorkshire
I've seen them John but with having a steel front it looks a proper ballache
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Is your Mini a flip front..
Main Build
Upgrade to Turbo
bennyy
Member #: 9037
Nope
As oli79 about his. think he has one on the inner wing.
nala56
Member #: 9661
If it's not, then only on the inside near the subframe bolt, and then you have got fumes getting in the cab.. Alan
Main Build
Upgrade to Turbo
bennyy
Member #: 9037
I have my coilpack mounted there, only thing I can do really is go in the inner wing or move my coilpack to the transfer case get some shorter leads.
nala56
Member #: 9661
What about my question, can i drain back into the distributor hole? from catcher tank..
Main Build
Upgrade to Turbo
i like the idea of it going through the manifold, however i think its more important to have water through there, have you ever felt the inlet manifold after even 10mins of running?
nala56
Member #: 9661
Not so, we were told on this forum not to take water though inlet, because, you’re trying to cool the carb, which is what you’re doing when you put on a intercooler, so i thought rather than have two 16mm pipes running across the engine, i would take the breather through inlet instead.. Alan
Main Build
Upgrade to Turbo
Yes, but unless your tank is not very tall and mounted very high up, you may struggle to get the oil to flow into it.
You don't want to drain the catch tank back into the engine. You drain the catch tank into something else.
nala56
Member #: 9661
Don’t want oil to flow in it, don’t want the oil to flow at all, just the gases, and if any oil gets that far up, it should flow back down to where it belongs in the timing case.. Alan
Main Build
Upgrade to Turbo
nala56
Member #: 9661
I know what you're saying and you may be right, this is what I want people’s opinions
Main Build
Upgrade to Turbo
In the 2 years i had a tank, it only ever had water in it and some mayo, i would not what this back in the sump.
nala56
Member #: 9661
I'm listening, never had one of these tanks before, this is why I’m asking.. Alan
Main Build
Upgrade to Turbo
Users viewing this thread: none. <- Prev
