Home > Help Needed / General Tech Chat > DSN/RetroSport Timing Cover
Ben H
Member #: 184
Melton Mowbray, Pie Country
Don't they normally leak from the cover to back plate not from the back plate to block. Looks really nice to me. Seems OK value, but not on my shopping list to a long time yet.
http://www.twin-turbo.co.uk
johnK
Member #: 690
Norfolk
As Ben says, a wobbly steel backplate is the cause of leaks, a rigid alloy backplate won't leak, the o ring on the cover plate won't leak. There is a built in position for a trigger wheel.
If Carling made Mini engines
There's just not enough distance between the block and a duplex to get an O ring seal inbetween.
I'm up for one, but I'll have to drill the front cover for a cam sensor :(
You could contacted DSN and see if they'd machine a boss for the cam sensor into one?
Aksherley, I've just checked out my alloy duplex and although it has stainless screws, the screw seats on the front are ferrous. So the cam sensor will have to go in the back. I'll just change one of the screws for a steel one.
The email said that they are going to do a 998 version without the breather on the back, so that will do.
Why use a tensioner with that Kent timing kit that has had the sprocket sizes designed to do away with chain slack?
johnK
Member #: 690
Norfolk
I simply don't believe any timing chain should be used without a tensioner, for accuracy and long life to the chain and sprockets - simple as that. This blocks been line bored as well - moving the two gears closer together. I'd like to do a variable cam timing kit for a Min but this isn't how I'd choose to do it!
JK
Fair enough, each to their own
jamestar
Member #: 9159
Devon
off topic slightly.. but:
http://www.slarkraceengineering.co.uk/camshaft_kit.htm
thoughts on this?
Dsn's machining looks superb do they do one offs?
Needed to cheer myself up/distraction from stress, so order placed for a black one :)
Nice... They looked good at bingley
It would be interesting to see the weight difference between one of these and a standard cover with a td back/front plate.
It will be heavier, but at least it will be the right thickness for timing chain alignment.
t@z
Member #: 452
Chester, UK
esp those with an ali back plate. thats pretty ruddy light that.
be interesting to see piccys once on
www.twitter.com/lilpinkiy
I had a chat with them at MITP last year about one offs,and the bloke did not want to know.
O well his loss.
Noice:
1050kg
The do look nice.
very nice in black.
ado15
Member #: 9838
JohnK's been doing a stirling job of answering your questions, but I thought I had better register!
In response to a couple of points......
It's actually over half a kilo lighter than the replaced standard parts.
O well his loss.
I don't think it would have been a case of not wanting to know. If it came across that way, I apologise on Dave's behalf. The biggest issue with one-off's is cost. Most people cough and splutter at the setup charge. Simple items can incur a setup of £200. Obviously, more complex items can be much higher.
Hope that clarifies it a bit.
Steve
DSN Classics Ltd
www.dsnclassics.co.uk
The 'td' back plate is a lightweight alloy one. probably at least 1/2 kg lighet than the standard one.
wez
Member #: 9271
Stoke on Trent
£200 for set up? how much do you charge per hour for machining?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
ado15
Member #: 9838
Sorry, missed that bit! So, I guess they would be about the same on that basis.
I obviously didn't explain it very well. The set-up relates to CAD/CAM time (getting the design on to the PC and defining tool paths, etc), plus manufacturing of tooling where necessary. Obviously, if you can supply a 3d model file that we can read, it would reduce the cost to some extent. But the CAM part would still need to be carried out and, depending on the product, tooling might need making to hold the piece while machining.
For simpler 'one-off' items, it might be more appropriate to have it made on a 'manual' mill rather than CNC. This would increase machining time, but reduce 'up front' costs.
CNC machining is more appropriate for production runs rather than one-off's.
Steve
DSN Classics Ltd
wez
Member #: 9271
Stoke on Trent
I understand what has to be done to get a cnc set up going, I'm a programmer/setter. It just seemed like a random amount most places quote per hour.
ado15
Member #: 9838
It's difficult to know how to explain when we don't know how much you know!! If that makes sense! Teaching granny to suck eggs, etc! The figure is based purely on experience with previous items and is only an example. We tend to quote set-up fee as one figure, plus cost per item thereafter. We aren't a machine shop, it's only there because we wanted to manufacture in-house. So it's distinctly possible we do it differently to everyone else *smiley*
As an aside, we don't programme on the mills. It's all done in OneCNC and transferred. Programming directly looks far too complicated.... we'll leave that to you experts!
Steve
DSN Classics Ltd
