| Home > Help Needed / General Tech Chat > A series block | |||||||
31st Mar, 2012 at 07:42:37pm
On 31st Mar, 2012 1994alex said:
Nope i got it wrong it isnt even mentioned in the vizard book my bad.
Is there anyway of boring it to a 1302? why do you want +30 so bad? i understand not wanting to wast 'good over bores' but i thought the +30 std overbore was dropped years ago, and hence you would either get really old stock or really expensive custom pistons the usual overbores are +20(~1293) +40(~1310) +60(~1330) 73mm(~1360) 73.5mm(~1380) Edited by Brett on 31st Mar, 2012. Yes i moved to the darkside |
31st Mar, 2012 at 09:52:07pm
I don't have any photos but most of the times its been the con rod end caps blowing the sides out
31st Mar, 2012 at 09:55:13pm
31st Mar, 2012 at 10:28:19pm
Be through to China soon! On 26th Jan, 2012 Tom Fenton said:
1st Apr, 2012 at 07:21:04am
On 31st Mar, 2012 RidingLow said:
I don't have any photos but most of the times its been the con rod end caps blowing the sides out So what has this got to do with block stiffness? On 13th Jul, 2012 Ben H said:
my bad.
