Home > General Chat > Project 64, 156mph in a Mini
did it die on the last run? sounded like there was no compression when he tried to re start it
You are right, no compression. I wonder if snapping the throttle shut after such a long run at high RPM at that speed with a prolonged overun period, exposed the hot parts of the chambers suddenly to a deep vacuum, no cool inlet charge and no fuel to cool the chamber, after all, everything sounded fine right up to when it stalled.
I'll bet they wouldn't have tuned the overun area of the map propperly, and I would be surprised if they used fuel cut on such a vehicle. There are engine dynos that can create these overun conditions, basically the brake is an electric motor that can not only impose a breaking load, but also maintain the engine rpm on a closed throttle
Edited by Sprocket on 24th Aug, 2012.
That is probably why they were searching for a new block and used the "Open 24hr" machine shop to prep a new block... They must have done some major damage.
So they broke the two engines they had. Expensive game that record breaking *hehe!*
Maybe it contributed to the "moment" the driver experienced on the slow down.
Such a shame but at least they are going howm with the record! I bet they would have Baught that before they started
Edited by gr4h4m on 24th Aug, 2012.
