| Home > Show Us Yours! > Homemade milling machine well kinda.. Connecting rods 998 and 1098 | |||||||
16th Sep, 2012 at 05:52:31pm
most of it was done by a sanding drum on a bench grinder, 400/800 grit then i went with wet and dry 1000 grit by hand, finished of with a polishing wheel on the bench grinder, for doing the centre of the rod i made up a few hockey stick shaped sticks and glued wet and dry to them took ages but i was waiting for parts
Yes i moved to the darkside |
19th Sep, 2012 at 08:43:13am
well i have done some work on one rod still need to do the inside tricky bits shall have a go the same way brett did his still plan to have the big end turned down i will finish as much as i can first tho to more or less complete a set so far i have lost 64 grams total weight over a stock rod there are still some tinny scratch lines i need to polish out but i think ill weight until the big end is done for that final polish
388 Posts Member #: 442 Senior Member Manchester |
19th Sep, 2012 at 08:46:26am
Wow thats one shiny rod! |
19th Sep, 2012 at 06:45:39pm
I cannot be arsed polishing. Send them for shot peening. Better and faster. On 13th Jul, 2012 Ben H said:
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
19th Sep, 2012 at 07:13:19pm
why is it at a dodgey angle? On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
19th Sep, 2012 at 07:37:05pm
998 rods, designed to fit down the bore. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
20th Sep, 2012 at 05:05:02am
the shine helps reduce weight extra oil just slips off |
248 Posts Member #: 7936 Senior Member DK-8450 Hammel. Denmark |
23rd Sep, 2012 at 03:27:06pm
If i have more toys than you when i die, I WIN |
23rd Sep, 2012 at 03:56:18pm
Just polishing the rod will actually weaken it as you have taken away the hard outer skin. You need to get them peened to replace what you have taken away. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
23rd Sep, 2012 at 05:04:46pm
Isn't it six of one, half a dozen of the other case? The idea of polishing is to remove any barely visible surface cracks or "V"'s where cracks can begin, also reduces weight and less oil sticks to the surface.
www.topcatcustom.co.uk |
