Home > Carls Guessing Games > It's beena while but can you guess what it is yet.
Looks like some kinda billet rear beam to me.
I know *wink*
That's quite an good intelligent guess Will , as i would expect form someone such as yourself, but wrong lol
Craigie-B
Member #: 9468
Wootton Bassett
Looked like some sort of arm ?
edit: new rear swinging arms?
Edited by Craigie-B on 17th Sep, 2012.
Supercharger mount?
Carl S
Member #: 1761
Stalker
I'd say billet 7 port as well :)
WINNER
Chalkie
Member #: 9764
Northamptonshire.
+1 either 7 or an 8 port :)
Very nice. Pricing? Or is that a WIP?
Aw, another lovely rear arm that (I presume) can not be used with cones?
I bet that billet set you back a few quid carl
Jim, the amount of money i spend on alumium in a year would make your hair curl,lol
what id not so evident is that what you see is half of an arm, theya re in two pieces, top and bottom, bottom shown, but it's taki ng an age to fettle and edit the posts for the machining as the cad cam is too powerfull for my M/C and its creating massive files compared to wjhat i am used to,
carl
Like but could never afford *happy*
oli79
Member #: 8480
Thats a nice looking piece of kit
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
sturgeo
Member #: 1778
Northants
Very nice, i can imagine sorting the fixtures for something like that will be complex enough let alone the cadcam work.
Johnny
Member #: 6926
Accrington
are they doweled together then seam welded?
Plenty of beer money left over from those!
Not srong there kid, two big lumps that will come in for another project, and a smaller piece i can use for another little job, so all in all quite economical use of material i think,
the two halves are located to one and other by the recess aronud the outer edge, male shown, then glued and bolted together, if that all adds up to a pain in the arse to do i have another plan,
Craigie-B
Member #: 9468
Wootton Bassett
Wooo :)
On 17th Sep, 2012 fastcarl said:
WINNER
carl talbot
Member #: 1323
[quote=fastcarl,17th Sep, 2012
[/quote]
Why the complication ?
So you can remove more material and make them lighter??
Good question Carl.and the answer was an attenpt to hog out the middle whilst leaving the cross section big meaning something as light or lighter but stiffer than other types available, but it hasn't quite worked out so far as there is more material to remove from them to bring the weight down to what i call accepable , and the second reason was i wanted a no conmpromise solution from materials readily available, i wanted people to appreciaste the effort that went into producing them,
and as i said above it it turns pout to be non economical i have another plan along the same lines,
Carl
On 18th Sep, 2012 carl talbot said:
On 17th Sep, 2012
^ more beer money then!
philc
Member #: 1346
bromsgrove
pill holder
any news on these? have had a look on the website and facebook page but not seen any info. i know you are a very busy man just curious.
