| Home > Show Us Yours! > The ClubVan... Back in business!! | |||||||
20th Mar, 2013 at 12:59:12pm
As per above its certainly had some identity change at some point, if I were you I would double check that the number on that plate rivetted to the slam panel matches what the logbook says. Otherwise you could be in a very sticky situation if anyone e.g. plod or vosa ever inspect the car for any reason.
1142 Posts Member #: 10165 Post Whore Stansted, Essex |
20th Mar, 2013 at 01:10:56pm
On 20th Mar, 2013 Tom Fenton said:
As per above its certainly had some identity change at some point, if I were you I would double check that the number on that plate rivetted to the slam panel matches what the logbook says. Otherwise you could be in a very sticky situation if anyone e.g. plod or vosa ever inspect the car for any reason. Yes Tom, checked that... all good. |
20th Mar, 2013 at 01:15:51pm
Subfame not too bad just filthy, a bit of surface rust present too... was thinking about powder coating possibly?
20th Mar, 2013 at 01:23:41pm
Brakes are 8.4" 2 pots as fitted to all 1984 onwards cars.
20th Mar, 2013 at 01:35:39pm
That's a tower bolt type frame, so the shell is '76 - 81. On 11th Feb, 2015 robert said:
20th Mar, 2013 at 01:57:10pm
Ok, concern starts to creep in. I have checked the logbook numbers against the slam panel plate which checks. Anywhere else on the car I could find some markings? |
104 Posts Member #: 10210 Advanced Member Durban, South Africa |
20th Mar, 2013 at 02:28:33pm
Love your wagon, definitely looks the part of a modified estate with so much potential for it to be customized. Tub the arches, drop it low with a wide set of arches and enjoy it to the fullest. I personally like it the colour that it is but what are your plans for the final look and colour of your little toy? In regards to your subframe, I'd strengthen it, lighten it and then paint it a contrasting colour to your final choice rather than powdercoat it, as if the powder gets chipped and moisture finds it's way inside, your subframe will rot without you even noticing it but then again that's only my personal opinion on it.
Edited by Miniac on 20th Mar, 2013. Life is always a matter of opinion and quite frankly, no ones opinion really matters. |
20th Mar, 2013 at 02:40:41pm
it is easy enough to swap the vin plates so the numbers are probably matching.
20th Mar, 2013 at 02:49:06pm
I thought they didn't get vins on the scuttle until the early 80s. My 78 car doesn't have one. On 11th Feb, 2015 robert said:
20th Mar, 2013 at 03:07:22pm
On 20th Mar, 2013 Rob Gavin said:
it is easy enough to swap the vin plates so the numbers are probably matching. not sure about all models but i'm sure there is also a vin or body number stamped into the bonnet gutter rail than runs along the scuttle. I know my estate does. On 20th Mar, 2013 evad1980 said: Ok, concern starts to creep in. I have checked the logbook numbers against the slam panel plate which checks. Anywhere else on the car I could find some markings? |
20th Mar, 2013 at 03:14:55pm
Thanks Miniac... I think I will tub the arches but I'm new to welding so may have to get a helping hand when the time comes, there will defo be wide arches on it! Final colour I'm not sure on yet, I was thinking of changing it as its getting completely stripped but I think it looks pretty cool in black so we'll see, I'm forever changing ideas anyway!! Yeah I'll take your subframe ideas on board, that makes sense. When you say strengthen, how would you do that?
On 20th Mar, 2013 Miniac said: Love your wagon, definitely looks the part of a modified estate with so much potential for it to be customized. Tub the arches, drop it low with a wide set of arches and enjoy it to the fullest. I personally like it the colour that it is but what are your plans for the final look and colour of your little toy? In regards to your subframe, I'd strengthen it, lighten it and then paint it a contrasting colour to your final choice rather than powdercoat it, as if the powder gets chipped and moisture finds it's way inside, your subframe will rot without you even noticing it but then again that's only my personal opinion on it. Good luck with your build mate. ![]()
20th Mar, 2013 at 03:19:48pm
Would it be fair to say that these were the brakes fitted to MG metros? The guy I brought it from said that's what he took them off.
Brakes are 8.4" 2 pots as fitted to all 1984 onwards cars. |
20th Mar, 2013 at 03:23:47pm
the brakes are mini, not metro. The metros all had 4-pot calipers |
20th Mar, 2013 at 03:33:07pm
On 20th Mar, 2013 Rob Gavin said: the brakes are mini, not metro. The metros all had 4-pot calipers
25th Mar, 2013 at 02:04:49pm
A bit of an update... I have been busy pulling the mini apart. I have it up on axle stands now, rear wheels are off and next job is to get the rear subframe out.
25th Mar, 2013 at 02:27:49pm
Tried to clean up the engine bay earlier on this year, stripped the paint, cleaned it, prepped it and then painted the drivers side of it. Even after a few weeks in the garage there were still a few bits of surface rust coming through again, looks like I'll have to go back to the drawing board on this one.
25th Mar, 2013 at 03:05:41pm
Rear subframe is a bit battered in fairness, quite a few years of rust and shite showing.
5th Apr, 2013 at 06:12:46pm
Ok so a bit more... pulled off the rear subframe, it was fairly battered looking. Considered making a spit to rotate the car but thought it'd be cheaper to prop it up on its side... so i did.
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
5th Apr, 2013 at 06:31:19pm
looking good what plans do you have engine wise Done now needs redoing lol |
5th Apr, 2013 at 06:31:47pm
So the underneath is not too clever looking, someone has got at it before with a welder.. Stevie Wonder by the looks of it!
5th Apr, 2013 at 06:34:05pm
On 5th Apr, 2013 wng691s clubby said:
looking good what plans do you have engine wise Well it's up at the BENROSS HQ as we speak, it's coming back a monster... His words!
5th Apr, 2013 at 06:37:31pm
Anyone looking for a new jack, check out this beauty.. got it in 'costco' last month, paid £107, worth every penny! A pleasure to use!
5th Apr, 2013 at 07:03:59pm
Looking at the body, it is all pretty standard stuff to be honest. Practice makes perfect! |
5th Apr, 2013 at 07:08:51pm
On 5th Apr, 2013 Rob Gavin said:
Looking at the body, it is all pretty standard stuff to be honest. Practice makes perfect! Yeah just hope my welding is up to it. Been practicing a bit on off cuts, seem to be getting there I reckon... trial and error!! |
16th Apr, 2013 at 03:30:49pm
So today I had a knock at the door, my knackered old engine had arrived back from Dr. BENROSS with a new lease of life. So finally, after a million and one private messages back and forth here she is...
