| Home > General Chat > Engine out again | |||||||
28th Sep, 2005 at 02:51:53pm
Or sorting out the cause of the problem - rather than a band-aid solution?
28th Sep, 2005 at 03:06:43pm
yes but that is not sorting the problem either.........the problem being the clutch
28th Sep, 2005 at 05:32:45pm
On 25/07/2005 13:48:31 Tom Fenton said:
I had the same idea Ben, although Dave is totally correct in what he says about getting rid of the root cause of the problem, which is the high clamping (and hence dis-engagement) pressures that seem to be required. However I don't know much about how you would go about reducing the spring force whilst keeping a high torque capacity, and so turned my thoughts to 'fixing' the problem. My idea was to see if you could increase the thrust area somehow, coupled with a better spec material. Or the other idea I had was to incorporate a pressurised oil feed from the main bearing into the thrust washer. This would neccesitate having a special thrust made up, that had a diametral groove, so that oil was forced through the clearance gap, thus creating an oil film to take the load and stop the thrusts getting chewed up. The obvious flaw in that plan is that the thrusts are of course 2 piece, and so to get an effective oil film lubrication working, the 2 halfs would have to fit together VERY well.... You mean similar to this, Dave?!
29th Sep, 2005 at 05:57:40am
On 28/09/2005 12:44:22 SumpNut said:
Would some sort of fixed thrust bearing at the other end of the engine, possibly running on the pully counter act take some of the force that the clutch is exerting and keep it off the thrust bearings>? How about a hydraulic release bearing against the pulley nut (area) Linked to the clutch master.......so when you push the clutch down it also pushes the crank back the other way relieving some if not all(depending on bore sizes)THe plressure on the flywheel side thrust washers
339 Posts Member #: 399 Senior Member Austria |
29th Sep, 2005 at 05:01:20pm
pictures of the disaster:
29th Sep, 2005 at 06:01:42pm
Looks like a load of scrap metal to me... I'm surprised the pistons hadn't nipped up in the bores actually.
29th Sep, 2005 at 08:00:38pm
holy shit...i'm glad i stopped driving mine as soon as the revs started dropping with clutch in, didnt let it get bad enough to stall the engine. On 20th Oct, 2015 Tom Fenton said:
30th Sep, 2005 at 06:35:36am
OKOK, I'll admit it. That thrust-breakdown is far worse than mine...
