Home > General Chat > Anyone used these harnesses?
Oli
Member #: 1910
Wilts
Get a good branded pair second hand pull that are out of date, nice and cheap then unpick label *wink*
Got to say, i'd be tempted with buying a branded set and removing the label
Dave, contact Willans, good to deal with and made in the UK.
I am sure they could make to your spec without labels if you asked.
Another vote for scroth harnesses here. Really good quality, easy to adjust, and don't cost the earth either.
What's a scrote harness?
Avoid 3-point jobbies, btw. Sure you know that, though.
You only had to ask mate,
http://www.ebay.co.uk/itm/BDSM-Male-Bondag...=item19e92667f2
*happy**happy**happy*
Why? I never had problems with my sparco ones.
supermotolee
Member #: 2153
kings langley
3 point harnesses are gay, seat belt style buckles are gay and under 3" width is gay and that's that!
In all seriousness willinans are the best out there in my opinion if you can stretch to it get the aluminium adjusters too as they are silky smooth to adjust,
When you are reaching into a single seater adjusting a crotch strap for a driver a silky smooth adjuster makes it slightly less awkward
That's gay?
Because you slide under them and die if you crash, unless you have them fitted 100% perfectly, which most people don't.
5 points don't have this issue.
supermotolee
Member #: 2153
kings langley
Love a bit of crotch strap camel toe!
But you need seats with 5 point use, I dont have this, only 3/4 point belts can be used correctly, they will be mounted at the correct angles and locations.
Make sure you tighten them around your hips properly, when strapping yourself in. That's the most common issue. If they aren't tight there, you'll go under them in a crash.
james962
Member #: 3663
Banbury
Slightly going OT but
If you didn't have seats with the hole in the base to accept the sub belt anchored below the seat, what are the thoughts about if you have a 6point and sitting on the sub belts so they come under the thigh to the buckle. They then attach to the same anchor points as the lap belts? Is this a no no?
page 16 in below:
http://www.schrothracing.com/sdocs/2009_Co...nstructions.pdf
This is what I use, JJC is something todo with demon tweaks, just a lot cheaper
http://www.jjcraceandrally.com/race/hans-s...er-hans-harness
Yeah, they claim to be separate but I think it's just demon-tweeks without a show-room or something. I got my race boots from JJC and they are great to deal with.
lee.pb
Member #: 9199
Lancashire
http://www.turbominis.co.uk/forums/index.p...4192&lastpost=1
very suttle logo too
