Home > Show Us Yours! > Nicky & Alex's motor
giallofly
Member #: 164
The Stig..
Newport Pagnell
Fab, was not meaning to sound funny...the block was 100% stripped,all core plugs out and hot wash dipped by a specialist, all you can see in the pic the the rough casting that has surface rust.
But thanks.
JF.
fab
Member #: 100
Parisien Turbo Expert
Paris' suburb
I saw that core plugs have been changed, I though that the white/ orange thing behind were should be a water pump was rust and calcaire deposit, which would have turned your engine as a very hot one . It was difficult to see what it really was.
fab
i dont suppose you have the spi flywheel lying around so that you can take a picture of how the trigger teeth are, im just intrigued by it
looking good in my unexpert eyes of building engines
Nicky
Member #: 333
Tadley, Hampshire
Er, should do. Now, what are trigger teeth? :$
the teeth round the outside, i think
grrrrrrr. I didn't think tigger had any teeth! Bouncing is what tiggers to best!
Boing!
From memory, I don't think the SPI cars use a trigger wheel and conventional crank sensor, instead they have a magnetic reluctor ring that a different type of sensor picks up.
Not sure if it would be possible to make use of this to drive an aftermarket ecu, I'm a hammer and spanners man so I'll leave that little conundrum to one of you whizz bang computer/software types.......
Edited by Tom Fenton on 6th Aug, 2005.
i meant the things that the sensor err senses on the flywheel
err basically a photo of the back of the flywheel
right bagsee jons skills for his next engine rebuild lol
MadMatt
Member #: 105
Brisbane ,Australia
left front tyre in the yellow mini is a little low in preasure *smiley*
www.miniman.com.au
looks about 7lbs to me ,or in other words spot on ,lol.
carl
Users viewing this thread: none. <- Prev
