| Home > Show Us Yours! > Ratty..... NA to TURBO ..... | |||||||
142 Posts Member #: 10808 Advanced Member leicester |
17th Apr, 2014 at 09:07:03pm
link to my TMF thread if your interested
19th Apr, 2014 at 04:27:04pm
Finished welding the top of the turbo box and dressed off the welds
Edited by rattydriver on 26th Jun, 2014. |
19th Apr, 2014 at 04:41:09pm
19th Apr, 2014 at 05:27:32pm
On 19th Apr, 2014 apbellamy said:
Nice job. cheers, a bit bigger than normal boxes but necessary..... |
19th Apr, 2014 at 05:27:34pm
started work on the gearbox, then need to source a few bits for the engine,, rings, MG cam , turbo curve dizzy....... May sell off some of the bits I got for the carb engine update... Edited by rattydriver on 19th Apr, 2014. |
22nd Apr, 2014 at 08:22:17am
was looking to see how to identify later cams and what was in my motor and found that the MG metro cam that I need has a recessed band after the first lobe.... I remembered a few year ago I had acquired some mini bit from my wifes cousin when he moved house... so I searched through the box and found these
Edited by rattydriver on 22nd Apr, 2014. |
26th Apr, 2014 at 10:19:22pm
went out and fitted an electric kenlowe fan to the engine bay, mounted to the subframe with brackets and to the stiffener bar..
Edited by rattydriver on 26th Apr, 2014. |
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
27th Apr, 2014 at 09:32:34am
Like the fan, looks good. Have you decided where to fit the boost gauge yet? On 25th Sep, 2009 mini13 said:
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
27th Apr, 2014 at 05:45:36pm
May need to make a different clock Cowel, if so I'll include it in that |
27th Apr, 2014 at 06:17:07pm
that turbo box has come out well mate Yes i moved to the darkside |
27th Apr, 2014 at 08:48:46pm
Cheers Brett , Nice and deep plenty of clearence |
2nd May, 2014 at 01:51:45pm
Received the 8mm valve guides this week... and sold my Kent 648 cam for £75 ... so have some money
2nd May, 2014 at 07:19:19pm
Good idea to sell the unwanted bits, all helps towards the build :). I've got the downpipe in the boot of the car, keep meaning to bring it round for you. On 25th Sep, 2009 mini13 said:
2nd May, 2014 at 08:31:20pm
chap who bought the cam may be interested in the dizzy aswell
9th May, 2014 at 07:21:59pm
10th May, 2014 at 01:42:24am
A stone chip covered turbo box might not be the best idea? On 13th Jul, 2012 Ben H said:
11th May, 2014 at 05:57:14pm
There's plenty of clearence . May also fit some heat barrier .. |
16th May, 2014 at 09:59:38pm
Bought some heat shield mat and sourced a fuel pressure regulator on Ebay... James brought down the
Edited by rattydriver on 16th May, 2014. |
22nd May, 2014 at 09:06:00pm
22nd May, 2014 at 09:10:11pm
Made a device for locking the flywheel, makes an easy job of undoing or tightening, flywheel, cam and crank pulley nuts
28th May, 2014 at 08:47:18pm
rebuilt the bottom end and painted
1st Jun, 2014 at 08:23:21pm
ground out the chambers
1st Jun, 2014 at 08:26:32pm
Next job to fit the valve guides and lap the valves in |
2nd Jun, 2014 at 08:45:52pm
Heads looking good! Will be interesting to see the cc when you measure them up! On 25th Sep, 2009 mini13 said:
6th Jun, 2014 at 07:18:45pm
done a bit more work on the head, ground down the guide towers a bit more
Edited by rattydriver on 6th Jun, 2014. |
