| Home > General Chat > Properly broken | |||||||
26th Oct, 2014 at 07:48:26am
Bit of JB Weld and that will be fine. On 11th Feb, 2015 robert said:
![]() 207 Posts Member #: 9045 Senior Member Wolverhampton, West Midlands |
26th Oct, 2014 at 09:52:10am
Mine did exactly the same
26th Oct, 2014 at 10:06:20am
Rob, as a minimum bin the oil pump and check all the shells. With the much metal debris floating about the pump will be scrap and the shells maybe scored :(
26th Oct, 2014 at 10:33:12am
That was my thoughts to be honest. The car was suffering low oil pressure when it warmed up so i was going to be digging anyway |
26th Oct, 2014 at 10:53:27am
The crankcase was all peppered on mine, as well as the crank webs, ended up doing a full rebuild with new oil pump etc. Even took my block in and had it acid dipped to clean the gallery's out Edited by Pauly on 26th Oct, 2014. |
26th Oct, 2014 at 11:59:44am
You can see why people fit windage trays, apart from the obvious oil being thrown about, it also stops a lot of gearbox flying around in the case of a breakage On 26th Jan, 2012 Tom Fenton said:
26th Oct, 2014 at 09:02:41pm
Well i started stripping the block to see how that was looking, 2 reasons, one being a drop in oil pressure when hot and the second being the obvious with the shrapnel.
26th Oct, 2014 at 09:49:40pm
good work with the gears rob!
26th Oct, 2014 at 10:02:24pm
You would still have had drive in 4th gear like that, although obviously debris is moving.
26th Oct, 2014 at 10:26:35pm
I thought that in hindsight too Steve but pretty sure i tried all gears.
26th Oct, 2014 at 10:57:10pm
On 26th Oct, 2014 Carlzilla said:
You can see why people fit windage trays, apart from the obvious oil being thrown about, it also stops a lot of gearbox flying around in the case of a breakage I use to think this was a valid reason for fitting a windage tray, but then the more I thought about it, the more I realised, that the tray is already a very close fit between the gears and the crank/ rods, that the energy of the departing teeth would be enough to move the flimsy aluminium tray into the path of the crank nad perhaps get tangled up making a much bigger mess to deal with, so I removed mine. I do have a cunning plan though
27th Oct, 2014 at 08:29:27am
I suppose building a box that doesn't grenade itself would be a start!
27th Oct, 2014 at 08:42:54am
a few photos of what we discovered when we went looking;
109 Posts Member #: 10368 Advanced Member Australia |
27th Oct, 2014 at 11:36:49am
just went hunting for some info on bmw squirters and found some oil squirter bling here http://www.e46fanatics.com/forum/showthread.php?t=720393
27th Oct, 2014 at 04:52:20pm
I fitted Mercedes jets, that open at 30psi oil pressure. Pretty easy fit; I just chose the first one that looked like the bimmer ones instead of trying to track them down.
27th Oct, 2014 at 04:57:05pm
interesting option Phil |
27th Oct, 2014 at 07:59:44pm
Another helical set bites the dust. On 7th Oct, 2010 5haneJ said:
27th Oct, 2014 at 08:41:32pm
Edit, I meant to post this in the other thread, which I have done, but will leave this here too anyway Edited by Sprocket on 27th Oct, 2014. On 26th Oct, 2004 TurboDave16v said:
