| Home > FAQ / Knowledge > Megajolt - A brief installation guide | |||||||
9 Posts Member #: 683 Junior Member Sweden |
6th Jan, 2006 at 09:13:47pm
HI !!
Edited by Ola on 6th Jan, 2006. |
7th Jan, 2006 at 11:43:09am
the out puts are numbered on the coil pack, have a looked for somoe small 1 2 3 4's
Edited by Nic on 7th Jan, 2006. |
7th Jan, 2006 at 11:47:40am
No idea without looking on the picasso site.
8th Jan, 2006 at 01:13:29pm
VREF is only used if a tps is used, as no one should be using it (as the MAP sensor is ideal for turbos) then it is left disconnected |
9th Jan, 2006 at 12:10:22am
whats better for use on an NA engine?
208 Posts Member #: 438 Senior Member London |
9th Jan, 2006 at 09:18:58am
Depends on how radical your camshaft is.
9th Jan, 2006 at 06:47:13pm
thought as much, cheers lads "Turbo's make torque, and torque makes fun"
1300 Posts Member #: 829 Post Whore essex |
9th Jan, 2006 at 09:35:25pm
the edis was it fitted to the cvh ford range
1293 Turbo mini
9th Jan, 2006 at 09:51:14pm
Is that aimed at me? Don't quite understand what you're asking?
9th Jan, 2006 at 10:14:38pm
yes sorry tom fenton (about pully) Edited by jimmy on 9th Jan, 2006. 1293 Turbo mini
9th Jan, 2006 at 10:18:29pm
Jimmy send me a PM if you want with your questions? Or do you want me to get your pulley machined?
27th Mar, 2006 at 11:06:19pm
if my laptop doesnt have a serial port, what are my options?
27th Mar, 2006 at 11:11:38pm
You can, I have heard of people having comms issues with this method though.
27th Mar, 2006 at 11:16:06pm
Cool, ill give nic a pm
28th Mar, 2006 at 10:08:41pm
I tried a belkin standalone converter, and it wouldnt have it,
2nd Apr, 2006 at 09:44:16pm
just a quicky does the 12v have to be permanently live or is switched (ign) live ok. about to fit me mj this week no longer a series, but still 1.3 turbo.
2nd Apr, 2006 at 09:54:14pm
ignition live m8
9th Jan, 2007 at 07:09:26am
On 15th of Aug, 2005 at 10:22pm Nic said:
Wiring The pip/saw wiring, and trigger sensor wiring is shielded and reduces the interference. The copper core from each is soldered to the other and then 1 wire runs to the body as an earth The std ford colours are black is 12v and brown is earth What exactly is this shielded wiring? Do need to buy special 'shielded' stuff? I only say this as on the some of the 'Motorcraft' modules Ive seen, a bunch of 3 or so wires are clumped together and another brown (presume earth) sticks out the back. Is this what youre refering to when you say: On 15th of Aug, 2005 at 10:22pm Nic said:
The copper core from each is soldered to the other and then 1 wire runs to the body as an earth ...does this mean theyre all earthed, or is it the shielding thats earthed? Thanks in advance, feel free to laugh, I know FA about wiring LOL "Turbo's make torque, and torque makes fun"
9th Jan, 2007 at 09:24:47am
Screened/sheilded wire is like the stuff used on TV ariels the outer 'braided' layer is an interferance suppressor.
9th Jan, 2007 at 12:42:23pm
The most important place to use the screened cable is between the VR sensor and the Edis Every day is a school day ...........
9th Jan, 2007 at 01:10:23pm
Yea I'd use screened for the sensor, for sure. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Jan, 2007 at 03:47:42pm
Thanks guys "Turbo's make torque, and torque makes fun"
9th Jan, 2007 at 06:40:49pm
As you look at nics picture of the edis module what is the 7th wire from the left that has nothing written on it and doesnt go anywhere? I appear to have 11 wires whereas that pic has 12. Also just to double check is the ground wire black with an orange trace and the PWR wire green with a brown trace? Thanks gav :) |
18 Posts Member #: 1067 Member |
15th Jan, 2007 at 06:50:39pm
Just though I'd say guys, the Sierra my VR sensor came out of didn't have a sheiled wire anywhere in the system. I used sheiled when I made mine up because it wasn't expensive, but it would seem that it's a belt-and-braces measure by Ford. |
16th Jan, 2007 at 08:22:58am
Gav the wire your missing might be the one for a rev counter, should be 3rd pin on the left (I think), I had to drill the connector out and add a wire as did many others. All the pics seem to have gone!!! I'll check my wiring tonight. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
