| Home > Show Us Yours! > Pulled my finger out lads | |||||||
17th Oct, 2005 at 02:44:46pm
If you like I'll buy you a tube and bring it when I come for that engine?
17th Oct, 2005 at 02:51:31pm
we use this at work. reminds me that i must "fetch" myself some.
17th Oct, 2005 at 03:04:49pm
IIRc is was speced by rolls royce for building Merlin engines!
AlexF |
17th Oct, 2005 at 03:07:14pm
sounds good! I'm at the stage where i've cleared enough room I can actually see it now! will have some pics In a day or 2. On 28th Aug, 2011 Kean said:
17th Oct, 2005 at 03:48:11pm
No locking strips on the transfer case stud/nuts ??
17th Oct, 2005 at 04:24:07pm
No, I've used Nylocs and loctite instead. Should be OK. The later cars used bolts with loctite instead of studs and nuts I believe?
17th Oct, 2005 at 04:30:25pm
Not loctite, but a thread-locking compound applied to the threads. Very common on OE applications On 17th Nov, 2014 Tom Fenton said:
17th Oct, 2005 at 04:36:11pm
Technical term.....Blue stuff
3rd Nov, 2005 at 10:24:07pm
A bit more progress-
3rd Nov, 2005 at 10:27:46pm
I have also found that I am missing the lower radiator mounting bracket.
3rd Nov, 2005 at 10:40:23pm
could be a mpi pump,as the alternator bolts to the head on them
3rd Nov, 2005 at 11:07:15pm
You could well be right there, will have to have a look next time I am under the bonnet of an MPi.
4th Nov, 2005 at 03:14:47am
That's a pump off an 'in-line' a-series i'm sure... That looks like a 'leyland' logo on it? unlikely to be MPi!
4th Nov, 2005 at 03:18:49am
Don't forget to leave the long bolts loose - the ones holding the fabricated steel engine mount to the gearbox. Makes it so much easier to settle the engine in the frame and line up the engine mount holes.
4th Nov, 2005 at 07:48:38am
I've got one you cna have tom. Ill sort it out for you this weekend with a pulley and then decide how to get it to you |
4th Nov, 2005 at 07:50:18am
You still after one of thoes rad brackets Tom?
4th Nov, 2005 at 10:00:17am
On 04/11/2005 03:14:47 TurboDave said:
That's a pump off an 'in-line' a-series i'm sure... That looks like a 'leyland' logo on it? unlikely to be MPi! Note there is no (by-pass) pipe going up to the head either... Even metros had the lump for the pipe there - it just wasn't drilled out. I did think it might be a pump from an 'inline' engine such as a Midget etc, but then surely those would also need the lug for mounting the alternator in the same way as on a mini? Iain, let me know about those bits, could run over one night and pick them up from you? Wil, cheers for the offer, will let you know if Iain can't find one. Cheers all.
6th Nov, 2005 at 10:33:18pm
Bracket now sorted courtesy of Iain, cheers!
7th Nov, 2005 at 08:07:08am
Morning all, as normal me and a few friends seem to be the last people on the planet to do what seems to be a trend now, and for the life of me I / we can't see why????
7th Nov, 2005 at 08:10:04am
I was thinking the same Fastest 998 mini in the world? 13.05 1/4 mile 106mph
7th Nov, 2005 at 08:18:25am
cheers Wil:) Best 1/4 mile 13.2 seconds @116 mph
7th Nov, 2005 at 10:02:44am
leaks... AlexF |
7th Nov, 2005 at 10:06:55am
I have used higher quality bolts on my engine, firstly as i believe the standard Austin Rover ones to be pretty low quality, and over 20 years old in some cases. Secondly however, I used different bolts as the originals were long gone as I stripped the engine some time ago, and I also have a box of good quality UNF bolts and sets in the garage.
7th Nov, 2005 at 10:24:54am
Yes i see your point Tom And Dave they are poor quality, just there are a bloody lot of them Best 1/4 mile 13.2 seconds @116 mph
7th Nov, 2005 at 10:26:00am
If you have cam wear issues have you optimised the valve spring fitted length? Maybe you need to machine your spring pockets in the head?
