| Home > Help Needed / General Tech Chat > What cam???????? | |||||||
3rd Jun, 2012 at 07:30:11pm
On 3rd Jun, 2012 Joe C said:
I was under the assumtion that cam grinders used the same "template" which inclues the bace circle, and gust ground the cam enough to get the desired profile whilst getting a clean cam nose. How can ou grind a cam using the same base circle of a standard cam, and still incrase the lift? You need to grind the base circle smaller to achieve a greater lift. On 26th Oct, 2004 TurboDave16v said:
3rd Jun, 2012 at 07:59:07pm
you cant, thats my point,
32 Posts Member #: 9976 Member |
3rd Jun, 2012 at 09:34:37pm
Interesting stuff.
3rd Jun, 2012 at 10:00:53pm
you cant, thats my point, to my knoledge a cam grinder is essentially a pantegraph. Edit **
with a pentagraph, the lift and the base circle will all change proportionally, but a regrind cam, as the base circle changes, the angel of attack on the open and close ramps are narrower and the lift per degree angle changes. Thats the bit I was trying to put across evenif its a bit fucked up
3rd Jun, 2012 at 10:31:15pm
Ah!
3rd Jun, 2012 at 10:47:21pm
There is deffo a difference between billet and regrind profiles, but what it actually comes down to I don't know, but as you can see in the crude schematic I drew, the difference can be easily seen between a profile that is exactly the same with the same lift, but on a smaller base circle. On 26th Oct, 2004 TurboDave16v said:
![]() 118 Posts Member #: 9965 Advanced Member Sydney, Australia! |
4th Jun, 2012 at 01:33:28am
both the RE83 and RE13T cams has a greater LCA angle for turbo and S/C use, this is so you don't blow all the fuel mix out the exhaust due to too much valve overlap. This makes it feel soft without any boost, compared to the regular RE83 and RE13.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson |
![]() 36 Posts Member #: 9909 Member Tyler, Texas |
4th Jun, 2012 at 01:52:21am
On 3rd Jun, 2012 Turbo Phil said:
On 3rd Jun, 2012 Craigie-B said:
Im going to be using a kent 266, i was told it was the closest to an mg metro cam that you could buy thats brand new and not worn to shit Or you could have bought a KC500 from Kent, which is the MG cam. :) Ive heard this and was planing to use one but i cant find them anywhere? -1974 Mini 1000 - BRG Turbo Build Soon to come
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
4th Jun, 2012 at 08:19:09am
Ill bear that in mind thanks :), but from what a friend told me and your guide for 130bhp suggesting a 266 I'm pretty confident I made the right decision On 3rd Jun, 2012 Turbo Phil said:
Im going to be using a kent 266, i was told it was the closest to an mg metro cam that you could buy thats brand new and not worn to shit Or you could have bought a KC500 from Kent, which is the MG cam. :) On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
4th Jun, 2012 at 09:13:05pm
so why does a billet cam give 4 to 6 hp more? Perhaps the difference in valve ramp due to the larger base circle? but I don't see the gain being as much as that though. Maybe Steve is talking in Baldwins. More or less Colin, Joe c also they are 100% accurate! A billet. A reprofile cam at best is only about 98% Craig b the 266 camshaft is a belter but please time this cock on at at 106 degrees or it will feel crap!
6th Jun, 2012 at 10:42:35am
Got a replay from MED on H/T cam i bought a few years ago.
6th Jun, 2012 at 06:12:53pm
so why does a billet cam give 4 to 6 hp more? Perhaps the difference in valve ramp due to the larger base circle? but I don't see the gain being as much as that though. Maybe Steve is talking in Baldwins. More or less Colin, Joe c also they are 100% accurate! A billet. A reprofile cam at best is only about 98% Craig b the 266 camshaft is a belter but please time this cock on at at 106 degrees or it will feel crap! On 10th Mar, 2012 theoneeyedlizard said:
7th Jun, 2012 at 04:54:08am
Inlet is perfect, exhaust timing should have 20/30° more duration: so about 286°.
7th Jun, 2012 at 05:06:53am
Lyons are still the kings!!
On 6th Jun, 2012 Craigie-B said:
Ahhh I timed it in at 106 as well well tried to atleast - will find out soon enough pahaha
:) is it as good as the avonbar ph2? Or is that not a fair comparison On 4th Jun, 2012 BENROSS said: On 3rd Jun, 2012 Sprocket said:
so why does a billet cam give 4 to 6 hp more? Perhaps the difference in valve ramp due to the larger base circle? but I don't see the gain being as much as that though. Maybe Steve is talking in Baldwins. More or less Colin, Joe c also they are 100% accurate! A billet. A reprofile cam at best is only about 98% Craig b the 266 camshaft is a belter but please time this cock on at at 106 degrees or it will feel crap! |
7th Jun, 2012 at 09:19:51am
Yes fabrice, Lyons are still kings
