Home > General Chat > How does 150-200 atw feels like?
I don't think a low level by-pass is needed with a rotrex charges as it has no low level boost.
I think you might struggle to get the power you want with this setup, you will also have a high boost threshold much like a turbo.
Map the available boost carefully and consider CR carefully. You might find a very high CR will be needed (maybe 10:1)
G13B
Member #: 1376
Wil, i guess 0.8 bar is enough for 150-170 atw at 7.000-8.000rpm (having maybe 130-140 N/A now), charger is rated for 1.6 bar maximum. I have stock suzuki cr, (top of my head 10.5) Ideal for me is to have N/A character but more power *wink* Time will tell were it lands powerwise, i have to make it work first *Confused*
Hedgemonkey
Member #: 360
Would that BOV be suitable for a suck through.....?
I'm looking at lashing up a suck through gas job and need a BOV.
would venting feul into the engine bay be a good idea?
come to think of it, you dont have a throttle plate to cause compressor stall so you wouldnt need a BOV?
G13B
Member #: 1376
well haven“t spend that much time on this little project lately, but i have fabricated the charger plate, bought a 48mm hsr carb and all the other parts required for a suck through setup, will use 1-2 saab diaphragma type dumpvalves for recirkulation. Maybe i fabricate a new steel inlet but think i will start out with the one i have first. Wonder if i need an oil strainer in the feeding hose?
