| Home > Show Us Yours! > My Project 84 Mayfair - GT1752 - now indoors and back underway | |||||||
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
7th Aug, 2012 at 09:19:59pm
Cheers Wil callipers are currently off the hubs so I will make sure they go back on correctly. |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
8th Aug, 2012 at 11:34:38am
A lot of good welding going on there Mate.. Alan Main Build
![]() 641 Posts Member #: 9937 Post Whore somewhereintheuniverse near selkirk scotland |
8th Aug, 2012 at 02:14:05pm
all good work mate so far apart from one slight detail ,the sills need to be vented or itl have as many holes as a teabag in very short time as they retain water without the said holes give em hell |
8th Aug, 2012 at 07:07:09pm
pretty much all the work from the first to pages of images has being redone, all the shit overlapping of repair panels and the none gen sill have gone. |
8th Aug, 2012 at 07:17:53pm
Some nice repairs there! Yeah I'd either chop them oversills off or at least put some vents in them.
8th Aug, 2012 at 08:39:27pm
i cut my bins out ,no probs with that give em hell |
15th Aug, 2012 at 11:00:27pm
boot floor is getting there...
16th Aug, 2012 at 07:07:32am
Looking good. It's not a drain hole. My car had a captive nut at either end. Im guessing its for assembly at the factory On 11th Feb, 2015 robert said:
16th Aug, 2012 at 08:25:04pm
On 16th Aug, 2012 apbellamy said:
Looking good. It's not a drain hole. My car had a captive nut at either end. Im guessing its for assembly at the factory Captive nut is there for fitting radius arm shrouds :) mine had a bolt in it not alot of good under 3 other sets of over sills... |
16th Aug, 2012 at 09:26:29pm
That is the front of the sill, I used the rear hole as a big plug weld to the reinforced part at the back that I had to replace.
22nd Aug, 2012 at 06:38:35pm
getting a bit done this week, can any one tell me what these bolts are for on the bulk head? I am sure there was never anything attached to them...
22nd Aug, 2012 at 06:49:53pm
the bolt holes are for left hand drive throttle pedal. On 11th Feb, 2015 robert said:
22nd Aug, 2012 at 07:19:48pm
good work mate im strugling with mine as ive no garage and its pissin down give em hell |
22nd Aug, 2012 at 07:37:57pm
cheers Andy they can go then. it's so good working inside progress is so much quicker and I can leave bare metal over night and not have to clean the rust off the next morning! I am renting a place just up the road from me, expencive but so worth it! |
29th Aug, 2012 at 10:11:55pm
boot floors finished off and primed same for the other sill, getting there body work wise. starting to get excited about a bit of a dry build...
30th Aug, 2012 at 07:19:05am
Yes. Buy the right stuff If something is worth doing, it's worth doing half of. |
30th Aug, 2012 at 07:26:20am
I wouldn't use those nuts. They appear to have a tapered seat even after machining. The wheels have a 90 degree seat, so the nuts will never fit securely. I wouldn't want to risk loosing a wheel... On 11th Feb, 2015 robert said:
Site Admin 6301 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
30th Aug, 2012 at 09:04:17am
On 30th Aug, 2012 apbellamy said:
I wouldn't use those nuts. They appear to have a tapered seat even after machining. The wheels have a 90 degree seat, so the nuts will never fit securely. I wouldn't want to risk loosing a wheel... This. |
30th Aug, 2012 at 09:16:20am
I don't really want to spend £50 on wheel nuts that still are not 100% perfect. I belive you have to run the washer the other way round as they are tapered?
30th Aug, 2012 at 10:30:32am
I got the nuts Carl recommended. They are a perfect fit on mine. I believe Carl stocks them. For me, spending £50 on nuts or risking the wheel coming of and hitting somebody is a no brainer. On 11th Feb, 2015 robert said:
30th Aug, 2012 at 10:32:10am
I used the wrong nuts on my old wheels, one almost fell off on the motorway. Scary. |
30th Aug, 2012 at 01:46:51pm
Edited by maccamcvey on 30th Aug, 2012. |
30th Aug, 2012 at 03:44:24pm
yes On 11th Feb, 2015 robert said:
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
30th Aug, 2012 at 04:32:31pm
i had the wrong nuts on my old 106 after picking it up from the seller, nearly 3 wheels fell off o.O |
30th Aug, 2012 at 04:50:19pm
That's just normal 'french performance' on 106's. |
