| Home > Help Needed / General Tech Chat > problem still there (part 2) | |||||||
15th Apr, 2005 at 01:43:34pm
On 15/04/2005 11:36:30 1275_dan said:
yeah this is like the 4th head gasget in the last 2 months,so something aint right. You've definatley got a problem if your having to change the head gasket that like that. Are you torqueing it down properly & with an accurate wrench ? Have the block/head ever been checked for flatness ? Phil.
15th Apr, 2005 at 01:53:26pm
Did you have the head skimmed? Did you use a new gasket each time? Is your torque wrench any good? Did you re-torque the head after 50 miles?
15th Apr, 2005 at 02:36:04pm
Might just be the head. If you're lucky.
15th Apr, 2005 at 02:39:26pm
i have an mg metro unleaded head on ebay... its not even been bid one at 99p no reserve...
15th Apr, 2005 at 03:12:11pm
whats wrong with the BK451 gasket set? thats the proper turbo one isn't it?
![]() 281 Posts Member #: 441 Senior Member |
15th Apr, 2005 at 03:30:06pm
yeah the head was recently refurbed by vmax,so it can only be the block.
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
15th Apr, 2005 at 06:59:48pm
Iain I have looked at the goodie you have for sale I may bid later for some things.
Edited by AllanMcD on 15th Apr, 2005. |
15th Apr, 2005 at 07:20:07pm
Along with a selection of bikinis, this item is of particular "interest" http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...item=6752149054
15th Apr, 2005 at 08:45:31pm
That was before the missus got her own ebay account! honest! |
15th Apr, 2005 at 09:58:49pm
ha ha ha!!!
15th Apr, 2005 at 10:04:52pm
1275-dan stick with it youl get there eventually most of us on there have had annoying problems i think.just work throuh things eliminating things one buy one, maybe get it to a rolling road and get them to sort it out ( you should be able to do it yourself tho)
15th Apr, 2005 at 10:21:54pm
Dan - don't assume it's the block. I'm not going to say it's the head, but wierd stuff happens...
Edited by turbodave16v on 15th Apr, 2005. On 17th Nov, 2014 Tom Fenton said:
15th Apr, 2005 at 10:26:02pm
Yes agree with the need to check head for flatness. Especially if it has been on and off 4 times now. If you can, get it on a surface plate and use feeler gauges under it as a start. TBH, it is probably worth asking a machine shop to give it the lightest skim they can get away with. If they take a first very light cut and it 'cleans' the surface all the way across the head, then it is OK and you will not have lost much volume. But if it leaves a low spot you might have found your problem.
15th Apr, 2005 at 10:30:36pm
well seeing as i've got the BK450 gasket now i'll give it a try, would it be wise though to get hold of the proper exhaust gasket? i'm guessing the steel rings on the exhaust ports are there for a reason? so the normal one wont take it? On 20th Oct, 2015 Tom Fenton said:
15th Apr, 2005 at 10:31:43pm
I would say yes try to get the proper gasket. More than anything else because it is such an arse getting everything off to change it!!
15th Apr, 2005 at 11:17:34pm
Yes, agree with Tom. The standard gaskets are pants, deffo use the one with the fire rings. or an all metal one as picture here.
15th Apr, 2005 at 11:32:04pm
ah sweet, i've got one of those all metal ones hanging on the garage wall.
