| Home > Show Us Yours! > K1100 16V Turbo build...now transmission build. | |||||||
20th Sep, 2011 at 10:10:06am
yes please. Also, what gearset did you go for? I dont really understand, there is the CBR1000RR and then there is the CBR1100XX. Which one did you go for? |
20th Sep, 2011 at 01:18:57pm
I'll be taking plenty of pic Robert, especially comparative ones of the two gearset.
20th Sep, 2011 at 02:31:47pm
If I can help at all with this Matty let me know, I'd love to get a sequential box in my mini. Team www.sheepspeed.com Racing
857 Posts Member #: 1778 Post Whore Northants |
20th Sep, 2011 at 06:41:56pm
Sounds interesting, sequential box combined with flatshift would be awesome. |
20th Sep, 2011 at 09:13:44pm
sounds very interesting matty
My build thread..
21st Sep, 2011 at 08:01:09pm
Cheers jim, I may need dome bits CNC'd.
Edited by matty on 21st Sep, 2011. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
21st Sep, 2011 at 08:12:10pm
Have you had any thoughts on what you will use for the transfer gears? On 26th Oct, 2004 TurboDave16v said:
21st Sep, 2011 at 08:18:00pm
Im not sure yet. All depends on the spacing between the two shafts.
21st Sep, 2011 at 09:54:13pm
Ive taken some measurements
22nd Sep, 2011 at 08:21:43am
will that bore be case hardened matt ? if so maybe better to take it out bigger and press a sleeve in ,otherwise as you machine through the hardening you get a tapered hole ,if you go through the hardening then a bit more your in the softer metal. and its a parallel hole . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
22nd Sep, 2011 at 06:53:26pm
If was thinking the same. All depepnds on how thick the case hardening is. Another option is to use the standard VFR outer bearing race pressed into the 1st motion shaft.
Edited by matty on 22nd Sep, 2011. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
45 Posts Member #: 9557 Member South region of the Netherlands |
22nd Sep, 2011 at 09:08:00pm
interesting I'm looking forward to see more of this build.
There ain't no milling machine like the one at home !!! |
![]() 384 Posts Member #: 4215 Senior Member |
22nd Sep, 2011 at 11:24:10pm
can wait to see more mate... keep up the good work and good luck |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
23rd Sep, 2011 at 08:19:52am
Good luck, im sure you'l sort this!! On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
23rd Sep, 2011 at 03:47:54pm
Generally when I put my mind to something I get it done...fingers crossed it all work out with this project! :)
23rd Sep, 2011 at 03:55:18pm
23rd Sep, 2011 at 04:03:13pm
What do you think about 1st gear? It might be a little on the short side. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
23rd Sep, 2011 at 04:04:54pm
I reckon a tall diff with this would be ideally suited. If something is worth doing, it's worth doing half of. |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
23rd Sep, 2011 at 04:05:07pm
Will be peeking an eye on this thread..
Dazed and Confused.... |
23rd Sep, 2011 at 04:07:50pm
Can a 2.9 be fitted to a Quaife? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
23rd Sep, 2011 at 04:09:24pm
Yes! I have one fitted to mine. If something is worth doing, it's worth doing half of. |
23rd Sep, 2011 at 05:15:34pm
it depends what you use it for road or drag,
Ideally I want a gear in between the clubman set and standard ratio. I was thinking of possibly changing to a 2.9 diff or maybe changing the drop/transfer gear ratio from 1:1 to give a higher overall ratio... On 28th Aug, 2011 Kean said:
23rd Sep, 2011 at 07:25:04pm
Ideally I want a gear in between the clubman set and standard ratio. ... er , isnt a standard 3.254 or something ? so doesnt that mean that it IS between the stock ,and clubman ?
23rd Sep, 2011 at 08:35:15pm
No idea mate, I'll try and find out.
23rd Sep, 2011 at 10:57:40pm
A+ series 1st ratio is either around 3.6, S's and MPI's are about 3.2 On 28th Aug, 2011 Kean said:
