Home > How To > Tips on Welding!!!
madcatminis
Member #: 5327
Dudley, West mids
Oh don't buy a tig welder for use on a car. Will be a waste of money. Get a good mig welder, a 160amp will be sound. Imagine trying to tig weld and feed in filler wire under the wing where it meets the scuttle. NEAR IMPOSSIBLE.
Regarding welding thicker material a 160amp welder will also be sound for welding heavier gauge, Just make sure that you weld prep the edges by grinding a 45 degree angle on them. Do a root run then capper run over the top until you fill the joint prep. *smiley*
So what's the general conscensus on wire thickness with a MIG?
I have been using 0.6mm and find it quite difficult to butt weld stuff as I can't get enough weld in before it melts and my seam welds look a bit small.
I'm just about out of wire, so was thinking about trying 0.8mm for a while to see what it's like.
Any thoughts/opinions?
I use 0.6 for the car and 0.8 when I'm doing heavier stuff
As above, 0.6mm for thin steel. Anything larger (ie, 0.8mm) and you will have to turn the current up too high and blow the base material away.
If you are having trouble with 0.6mm, try changing the current setting or wire speed.
0.6mm is the best for car body panels if you have the other settings right.
Thanks
Getting a better welder keeps corssing my mind. I have a clarke 120E, but the power controls are switched rather than on a dial. I had better results with the welders I learned on at evening college (big powerfull things...) I was thinking something with better controls and a little more power (150/160 amp) might give better results.
Or is that just a poor workman blaiming his tools *wink*
My Snap on 130 has switches for power, 1/2 and Min/Max, it does the job fine for me.
I personally just use 0.8mm wire. Dont have any problems really.
I hated my little hobby mig with crappy gas bottles. Since i splashed out and got a decent machine i have never looked back! Well worth the money!
i use 0.8 on CO2, i found 0.6 a little too... er i dunno weedy, doesnt like welding on higher power settings especially upside down lol
i think its more a case of trying them both an seeing witch suits your welding style most
Thanks for the advice. I gues I'll get a small roll of 0.8 and give it a try on some scrap...
Don't forget if you do try 0.8, you'll need to change the tip to suit.
Good point...
EDIT: I feel a trip to machinemart coming on, I need a new shroud anyway...
Edited by apbellamy on 20th Aug, 2009.
turbominivanman
Member #: 1504
Westbury, Wiltshire
0.8 mm and Argoshield Light for me - have always had great results with that combo.
I did use CO2 for a while but converted to argon & CO2 mix (Argoshield Light) after I quized my welding supplies bloke one day. He informed me that my CO2 was such a cold shielding gas it was the source of my panel warpage and he said it introduces the risk of moisture entering the weld pool.
Everything got a great deal better when on Argoshield.
Also, as I've said before, I also use my 0.8 mm mig to weld aluminium and stainless for which I use pure Argon and change the wire rolls over. Halfords do Ali and St Steel 0.8 mm rolls for about £8 a piece and a small bottle of Argon is about £15. Good for brackets, small jobs and welding the die cast ali stuff like thermostat housings.
Richard.
I use argosheild from BOC, can't be bothered with the liitle PITA bottles.
I think I'm going to give a small real of 0.8mm a go.
Mr Joshua
Member #: 1954
Luton Bedfordshire
When useing Argon dont forget the unfortunate lesson learned by that chap in the US when he used brake cleaner to clean the area to be welded!
Best tip I can offer is get a photo reactive shield. this has improved my welding immeasurably
Edited by Mr Joshua on 21st Aug, 2009.
Own the day
might be worth cleaning or replacing the torch liner as well; especially with the cheaper machines, the wire can cut a groove in the liner and affect the wire feed;
Users viewing this thread: none. <- Prev
