| Home > Show Us Yours! > TIG Welding Learning Post | |||||||
27th Dec, 2009 at 01:31:05pm
Looks like its been welded along a side, then missed one, then welded another side. Or, its been artifically cooled as its been welded.
On 27th Dec, 2009 apbellamy said:
So why all the different colours in the weld in the pic above?? On 19th Jan, 2010 wil_h said:
549 Posts Member #: 5327 Post Whore Dudley, West mids |
27th Dec, 2009 at 07:58:57pm
The difference in colour is all down to torch angle. If you fillet weld a round tube as you go around the weld is not getting argon shielded and discolours. The discolouration is fine as long as it's not oxidised. Titanium discolours like a bitch if you don't get it right. Anything other than silver or a light straw colour on titanium in aerospace is a failure. At work I use a 12 millimetre wide ceramic for everything from 0.21m up to 4mm. Also your travel speed will effect the colour of a weld. Slow is okay but too fast and the weld will appear grey. Grey means that is on the boarder line to oxidising. |
5th Jan, 2010 at 01:19:13pm
I've got my hands on an old AC/DC tig, so expect some dodgy photo's from me.
5th Jan, 2010 at 01:24:32pm
Good Lad!
Edited by Joe C on 5th Jan, 2010. On 28th Aug, 2011 Kean said:
5th Jan, 2010 at 01:26:50pm
I pay around £150 a year for rental for two Y size bottles, plus the gas.
5th Jan, 2010 at 02:56:50pm
On 5th Jan, 2010 Paul S said:
I'm waiting for Roderick As above, the only difference being that I rent cylinders, not bottles ![]()
The "Y" size is much more cost effective if you use a fair bit, rental and refills are only about 30% more expensive but they are twice the capacity of the "X" size. So there is a break point between rental costs and gas costs depending on useage. It appears BOC are now offering 5 year leases again (which they used to do but stopped it) at lower prices per year than the normal yearly rental so I'll probably swap to that as well next time I need an exchange cylinder :) Schrödinger's cat - so which one am I ??? |
857 Posts Member #: 1778 Post Whore Northants |
5th Jan, 2010 at 03:02:06pm
On 5th Jan, 2010 Rod S said:
The "Y" size is much more cost effective if you use a fair bit I'm hoping he's going to teach me to weld so that'll use a fair bit of gas! |
5th Jan, 2010 at 03:32:39pm
Reminds me of this http://v8tvshow.com/forum/index.php/topic,2016.msg3488.html |
![]() 695 Posts Member #: 984 Post Whore Westhoughton, Bolton |
22nd Jan, 2010 at 05:39:43pm
What do people think to this?
22nd Jan, 2010 at 05:43:55pm
When I was looking to buy my TIG off ebay, I looked for people in the sellers feedback who had previously bought the same thing, and sent about half a dozen of them a message, explaining that I was looking to buy one, and asking if their machine was OK, did it work, what did they think of it etc.
22nd Jan, 2010 at 06:07:05pm
I know alot of TIGs enable you to arc weld too, has any one actually ever used this feature? On 19th Jan, 2010 wil_h said:
22nd Jan, 2010 at 06:16:06pm
Mine supposedly does, came with some arc welding pliers too, I haven't tried though.
22nd Jan, 2010 at 07:50:00pm
They arc weld beutifully.... Really stable. It's like the difference in going from C02 to mix in you MIG welder.
22nd Jan, 2010 at 08:11:45pm
Cheers. I have messaged a few people to see what they think of them. Also i will mainly be using it for the plasma cutter but i thought a tig could be useful at the same time. |
19th May, 2011 at 06:54:38pm
Tips from welding up my manifold:
Edited by Paul S on 19th May, 2011. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
19th May, 2011 at 08:14:02pm
exactly what Paul said!
19th May, 2011 at 09:33:27pm
I'd agree. I clean my alu rods off with scotchbrite before using them.
27th Oct, 2011 at 05:10:32pm
I thought I'd keep this in the same post.
27th Oct, 2011 at 05:51:24pm
I'd say yes too hot,
27th Oct, 2011 at 06:42:46pm
Looks a lot of current. How much were you using there?
27th Oct, 2011 at 06:47:31pm
I don't know what welder you are using, but I found with mine that the footpedal overode the dial setting for amps. Therefore it was easy to use too much amps/heat with the foot pedal.
27th Oct, 2011 at 06:55:35pm
Im using an r tech. I think the base current was set to 85 and i switched pulse off as i was using the pedal. The pedal was about 2/3s down for the run so im guessing thats about 50amps? i tried it without the pedal but found as soon as you let go of the button the heat would just go and you'd have to start the pool again. With the pedal i found there was more control. What kind of base current would you suggest for that thickness? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
27th Oct, 2011 at 07:36:10pm
On 27th Oct, 2011 matty said:
Im using an r tech. I think the base current was set to 85 and i switched pulse off as i was using the pedal. The pedal was about 2/3s down for the run so im guessing thats about 50amps? i tried it without the pedal but found as soon as you let go of the button the heat would just go and you'd have to start the pool again. With the pedal i found there was more control. What kind of base current would you suggest for that thickness? When the pedal is connected, the rotary dial on the pedal controls current. Not the one on the machine. So whatever the dial is set to, is maximum pedal. Although for steel or stainless, pedal isnt really needed. 9.85 @ 145mph
27th Oct, 2011 at 09:00:09pm
Stevie, you say pedal isn't really required for stainless or mild, why is this? Any hint or tips welcome :) May inprove my ally welding! On 19th Jan, 2010 wil_h said:
54 Posts Member #: 8588 Advanced Member Yeovil |
28th Oct, 2011 at 11:13:10am
Here are some examples I did using a pulse setup on a tig welder - with no filler rod.
Graham |
