Home > Show Us Yours! > Morris mini sleeper-update 2012
That was quick well done.
Fingers crossed eh!
Good to see it back together. I saw your old block up at Steve's, it was a bit of a mess!
oli79
Member #: 8480
Thanks-Never a truer word spoken it was fooked, didnt take me camera when I went to see Steve though, anyway if anyone is after a very large but never-the-less very effective paper weight, please speak to Benross!!!
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Nope he doesn't I asked him for it. Already gone to tip.
oli79
Member #: 8480
Dont tell me hes been tidying up!*surprised*
tomkidd
Member #: 1962
Lancaster
Glad to see it is back together. I'll make sure my clutch is correctly setup when I start to run my new engine...
baker_boy
Member #: 9226
Rushden
thats a really nice setup you got there, hope your lucky second time around..
i got nothing but time..
oli79
Member #: 8480
Small update nothing special, done a few bits as avon took its toll, same car now with no oil leaks(for the moment anyhow)!
but now has:
Switchable leanoff for cruise, as well as another of these behind the dash on the back of my bleed for switchable boost
and a quick release steel bonnet
also had a big spark plug trauma, been running brp8es and then rn7yc's, once back together it dropped a plug-it was fine on low boost then a flick to high boost and a bang from under the bonnet and a wisps of white/grey smoke from the exhaust and a very black no4 plug!
So gone onto the unipart ngk7's equivalent on advice from John and so far its all good, ordered an inlet temp gauge so thats next.
ta
oli
Edited by oli79 on 22nd Sep, 2011.
bennyy
Member #: 9037
Doncaster, yorkshire
Oli does the part throttle lean off make a substancial difference to afr s on cruise? Considering doing this to mine.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Awesome! Coming to RR day with it? *wink*
Still looking great.
Offer's still there to twiddle with your suspension if you want.
oli79
Member #: 8480
To be honest bennyy I dont know yet, I have only took it out once since the plug issue and didnt really get a chance to test it properly, I did have a quick stint at 55mph ish and turned it on and yes is did seem to lean off but needs a proper run. I may be wrong but I think Robert has something similar on his car and may know the answer.
oli79
Member #: 8480
Yeah sod it I will come if there is room, I had thought things were fully booked but i will come if there is a place, got the monday off work anyhow as I am using up some holiday, may need this to get over the hangover! just let me know the details
ta
oli
oli79
Member #: 8480
Hi thanks Will, I will definitely take you up on your very kind offer, things are just hectic at work and at home at the mo, as soon as I have a little time, and obviously providing you are free I will pop up for your help.
ta
oli
on my last lump I ran cold plug (equivalent to NGK 9's) and it was fine, even in the snow, on this lump it fouls them up and Ive had to drop back to 7's, all thats really changed is the cam and the CR from 8.5 to 8.2
Looking good, lots in there mate *hehe!*
oli79
Member #: 8480
Thats is interesting, I suppose plumped for cold plugs as a result of tm searching and also in fear of melting something at high boost, first was ngk 8's which ended up fouled when I had my first ignition problems then went to the champ rn7ycc's which have done only a few hundred miles(and a lot of avon park hammer!) before the one plug failed, here is a pic of two of the running plugs and the failed no 4 on the left (please excuse my scummy thumbnail!)
ta
oli
c2_mad
Member #: 4215
just read through your entire thread, really felt for you when you had the streak of really bad luck, good to know all is sorted now.
quick question, how did you go about making your quick release bonnet, really like that idea
cheers
oli79
Member #: 8480
Thanks-will put some picks up of hinges tonight
ta
oli
cheers
oli79
Member #: 8480
After some cooling issue on the rr day and some ic problems at Santa pod, I have made a few changes as an experiment mostly after talking to Robert on the rr day regarding ducting air in the right direction ect, so sticking with a side mount rad for now.
Inner wing duct thingy to radiator similar to cubmans with rubber flaps around the rad
New intake pipe in silicone with an alloy 45 this time, that piece of flexi duct I had was shite, also 2wd cossie intercooler and an air temp gauge connection in top plenum hose
fg bonnet and holes ect, no paint as yet and after spamming mikes thread to death decided to get another mk1 steel grill, going to paint that in oew
rubber intake scoop
dash is in, my new view of procedings
It seems to be a bit leaner with the new ic, probably because this one works but as I never had the IAT gauge on it before i have no comparision. Took it out breifly the other night, outside air at home was 13 deg c, intake got up to around 21 deg c on 15 psi-is that bad/good/indifferent?
Edited by oli79 on 2nd Apr, 2012.
bennyy
Member #: 9037
Have to say Im not a fan of the new ic set up compared to the old one looks wise, but if it works who Cares, and yes 8deg above ambient is pretty good going. See you at York
Edited by bennyy on 3rd Apr, 2012.
Looks good Frank.
Looks good I like the rad duct.
oli79
Member #: 8480
Thanks chaps, made a lethal sort of fan/ propeller thing and a screen over the front of the car to piss about with air flow and it seems to get a real good flow through it. I agree though benny its not pretty but needs must, i need to do some more testing, will see you Sun but might have to bring a snow shovel!
bennyy
Member #: 9037
We shall see, according to my phone we have no snow but rain on the Sunday, sat looks ok though, you camping or going on the day?
