| Home > Technical Chat > Blow through HS8 issue | |||||||
28th Aug, 2018 at 02:12:09pm
What engine is this? If you are going to the hassle of injection I don't understand why you would use a "electronic carb" single point injection throttle body. Instead I would use 1 injector per cylinder and conventional multi point injection, much easier to set up, far better driveability, scope via injector size to be able to fuel up to 1000bhp with ease!
36 Posts Member #: 11630 Member |
28th Aug, 2018 at 08:02:01pm
Its VW motor. Jonny, I might just try a better ignition 1st.The fueling isn't really a problem ,its the high rev/load that's the issue. It cuts outs like some sort of soft cut limiter, apparently its spark blow out , due to me only using points and a standard coil. I think anything has to be better than points. |
