| Home > Help Needed / General Tech Chat > No 4 cyl cooling | |||||||
76 Posts Member #: 61 Advanced Member |
6th Apr, 2004 at 01:41:39pm
Hi! |
6th Apr, 2004 at 01:55:06pm
All my trubo heads already have the hole a tappings for the std mini heater valve...
AlexF |
6th Apr, 2004 at 07:07:36pm
oh, off the topic, but i will need to drill mine for my mini when the engine goes in, is it a case of just basically, drilling it through? Or is it a properly machined process? Also is there a way to connect the pipes arround so that the heater is still connected and everything, but without a heater tap? Im trying to lose alot of the visable pipes thats all, and my heater tap is always on full anyway as i have no pull mechanism. Want to be able to do it wihtout compromising the heat loss. Thankyou! Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
7th Apr, 2004 at 05:36:47pm
just drill it out with a 10mm bit, might be an idea to use the hoover to suck the bit of swarf away as you drill. worked for me! On 21st Jan, 2011 fastcarl said:
![]() 2641 Posts Member #: 19 Post Whore newcastle |
7th Apr, 2004 at 06:11:25pm
nought works for me!! Everyone knows that instructions only have to be read if the thing doesn't work....
7th Apr, 2004 at 09:56:41pm
HAving said that my newest haed doesnt :S
AlexF |
9th Apr, 2004 at 09:45:24pm
Alex, you will find although the water hole is not drilled, the threads will be tapped Team www.sheepspeed.com Racing
10th Apr, 2004 at 12:32:58am
your dead right Jim,
AlexF |
