| Home > Help Needed / General Tech Chat > Lambda sensor mounting | |||||||
![]() 164 Posts Member #: 206 Advanced Member Milton Keynes |
6th Apr, 2004 at 01:57:42pm
Could anyone reccomend a distance to mount a lambda sesnor after the turbo ? 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
6th Apr, 2004 at 02:06:21pm
I think mine is about 4" from the turbo.
6th Apr, 2004 at 03:30:48pm
They work better when hottest - i have mine in my 'elbow' and have no problems. I would keep it less than 6" away for sure... On 17th Nov, 2014 Tom Fenton said:
6th Apr, 2004 at 03:57:52pm
I've had a boss welded onto it - luckilly the elbow is made from cast steel, so welds quite easilly. You must remember to drill and tap the boss first though and position the boss over a hole in the elbow that is larger than the OD of the Lambda thread (M18??), as when welding, all the carbon is drawn out of the cast and it goes super-hard!
6th Apr, 2004 at 04:22:59pm
I've just got a boss welded on the down pipe, it certinally gets hot enough there.
6th Apr, 2004 at 04:26:06pm
I would never have thought of that dave LOL
AlexF |
6th Apr, 2004 at 05:12:11pm
I haven't got any engine management (yet). I've just got a lambda sensor meter (Green for rich and red for lean).
969 Posts Member #: 47 Post Whore Not very sunny swanage |
6th Apr, 2004 at 06:48:56pm
am i right in thinking that in thoery these will tell you when your running massively too lean and are likely to start melting things. if so then they would seem to be a bloody good investment, if not, then what do they do?
And on the 7th day........... God created turbochargers! |
6th Apr, 2004 at 07:46:49pm
only a wide band sensor will tell you that, the cheapo gauges using std O2 sensors arnt any use.
AlexF |
6th Apr, 2004 at 08:44:04pm
That's what I use mine for. I think it's got something like 8 LEDs. As I said before green for rich and red for lean with a few yellows in the middle which indicate somwhere about right.
6th Apr, 2004 at 09:04:40pm
where did you get it from wil and about how much are they no longer a series, but still 1.3 turbo.
263 Posts Member #: 115 Senior Member Austria, near Vienna |
6th Apr, 2004 at 09:30:06pm
Hi Folks!
Bimmer Twinky headed and turboed A-Series:
7th Apr, 2004 at 07:17:07am
The thread is M18x1,5 on most lambda sensors. Same as Pinto spark plugs. Neat to use as afterburner plug, I bet they would be impressed in Miniworld vs. Minimagazine. How about some road fame for you RR session, just use another coil and run a lead from it ??? |
7th Apr, 2004 at 08:05:40am
Just checked, my meter is a 10 LED type but I think I paid ?100 just for that. the Lambda sensor was about ?30 and who know where I got the boss from.
7th Apr, 2004 at 08:56:17am
Which wide band kit did you go for? I still haven't made my mind up and brought one yet!
AlexF |
![]() 265 Posts Member #: 68 Senior Member Coventry |
7th Apr, 2004 at 12:52:34pm
if you have any electrical experience....
Edited by mini-marauder on 7th Apr, 2004. Sooperdooperturbocooperexpertengineering! |
148 Posts Member #: 98 Advanced Member Slovenia |
7th Apr, 2004 at 02:09:57pm
I am going to make lambda read too, from this site: It is on german: http://www.taunus-biker.de/content/show.ph...3#Bezugsquellen
7th Apr, 2004 at 03:07:50pm
LOL... i cant understand a word of that!! will try sticking it in a translator... Sooperdooperturbocooperexpertengineering! |
7th Apr, 2004 at 05:32:18pm
Have a look at this: http://wbo2.com/
7th Apr, 2004 at 06:00:48pm
As dave said, i would nt run a modded engine without one. full stop 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
9th Apr, 2004 at 09:49:25pm
My narrow band lambda has saved me hours on the rolling road, and loads of cash, I cna roughly set my car up before I get there Team www.sheepspeed.com Racing
11th Oct, 2006 at 09:36:59pm
On 6th of Apr at 03:30pm TurboDave said:
They work better when hottest - i have mine in my 'elbow' and have no problems. I would keep it less than 6" away for sure... Dave. Do you remember that we discussed this at Avon? You said it was perfectly OK to mount the sensor at the lower elwob if you know what I mean down by the diff housing. This because at the turbo elbow it gets too hot. Which is right? :) I remember you said that Jim's was a but too near the turbo. Also, if fitted in the cast elbow, wouldn't thi obstruct flow a lot? On 13th Jul, 2012 Ben H said:
11th Oct, 2006 at 10:45:58pm
this is about the 6th old thread youve brought back to the top in that last couple of days? whats the deal with that???? And on the 7th day........... God created turbochargers! |
![]() 162 Posts Member #: 1252 Advanced Member Cornwall |
11th Oct, 2006 at 10:53:27pm
glad he brought this one up it's very interesting reading! |
11th Oct, 2006 at 11:55:03pm
On 11th of Oct at 10:45pm nutter driver said:
this is about the 6th old thread youve brought back to the top in that last couple of days? whats the deal with that???? Why start a new thread when it's been half discussed previously? Much easier to search for information at a later date if all similarish info you need is in one thread not four. So, is this a problem for you? On 13th Jul, 2012 Ben H said:
