| Home > Help Needed / General Tech Chat > oil leak arrrrgh!! | |||||||
11th Jul, 2006 at 08:42:14pm
im at my wits end. after replacing gearbox this weekend went out for a drive on sunday came back oil dripping out of the little hole in the flywheel housing. even though everything were new. so i took off the clutch flywheel etc and the tranfer case(which were a real bastard) replaced transfer case gasket(thought it may have been leaking through the little dowel. replaced the crank seal as well. went out tonite come home and guess what oil dripping again. the crankseal were a tight fit on the gear/shaft thing. where as my original one was slack!
11th Jul, 2006 at 08:44:30pm
oil left over from the original leak ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 695 Posts Member #: 984 Post Whore Westhoughton, Bolton |
11th Jul, 2006 at 08:47:46pm
Primary Gear? They can cause a leak cant then? |
11th Jul, 2006 at 08:54:00pm
pretty sure its not left over oil im gonna give it another run now i cleaned it all out tho.
11th Jul, 2006 at 09:55:49pm
you may have nicked the seal if you did not tape up the primary gear splines for the clutch when fitting the cover on this is where most peeps go wrong
11th Jul, 2006 at 09:57:20pm
yeah mains and distorting the seal. or the seal isnt fitted square?
11th Jul, 2006 at 09:59:35pm
pretty sure the seal isnt nicked i fitted the seal to the primary gear first then fitted them as a pair so no chance (i dont think) that i could have damaged it.
11th Jul, 2006 at 10:08:39pm
like i said, if the bearings arent running true they wont run correctly in the seal either, distorting it and causing a leak. dont think its likely though. |
11th Jul, 2006 at 10:10:29pm
as the crank will flex up and down with the goosed main bearing on the clutch side
Edited by BENROSS on 11th Jul, 2006.
11th Jul, 2006 at 10:13:16pm
oh! as iain says go for the crank case breathers first!
11th Jul, 2006 at 10:15:54pm
cheers for you advise. ill have another look tomorrow night. no longer a series, but still 1.3 turbo.
255 Posts Member #: 520 Senior Member nr hull |
11th Jul, 2006 at 10:23:22pm
yeah the breathers can be a pain, ive had an awfull oil leak for ages that i couldn't stop and it turned out to be blocked breathers, i cut the top off the clutch side one and fitted a filter straight to the top and its all fine now touch wood. got to be worth a look.
Edited by hippyinamini on 11th Jul, 2006. doh! why did i start messing with it!
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
11th Jul, 2006 at 10:29:58pm
check the gear on the end of the crank for movement, it doenst matte how good your mains are or how good the seal is if the oil is getting between primary gear and crank. I have seen a goosed (from new) primary gear in less than a thousand miles before.
11th Jul, 2006 at 11:14:37pm
your mains cant be that bad can they? isnt the engine fresh? plus it wasnt doing it a retro cars
11th Jul, 2006 at 11:15:39pm
I'd double check the breathers situation, make sure that the turbo isn't pressurising the crankcase somehow as well.
12th Jul, 2006 at 01:45:01am
Have you seen the price of primary gear thrusts On 26th Oct, 2004 TurboDave16v said:
12th Jul, 2006 at 10:47:17pm
i recon its either badly worn primary gear bush or the oil drain holes in the primary gear are blocked ( very common) as said blocked breathers (mine were blocked so removed them cheep breather filters and she is fine now). always looking for them bigger bunches of bannanas |
14th Jul, 2006 at 10:42:48am
right i seem to have sorted it!
Edited by Carl on 14th Jul, 2006. no longer a series, but still 1.3 turbo.
