| Home > Help Needed / General Tech Chat > ***** URGANT HELP NEEDED ***** | |||||||
![]() 94 Posts Member #: 400 Advanced Member Shrewsbury |
12th Jul, 2006 at 09:46:42pm
as most of you know, i have has some problems with my crank, today i had it back from the machine shop. has been reground and new bearings have been supplied.
If it breaks... build a much faster one |
12th Jul, 2006 at 09:48:52pm
To be honest buddy if you still have the same problem with the crank locking up with a newly reground crank and matching bearings, it points to a problem with the block.....e.g. one of the bearing caps is either not locating properly, or one of the caps is distorted?
12th Jul, 2006 at 10:42:20pm
yes i agree to best bet it to one cap at a time to see which one it is causing the problem and make sure you get them the right way round as the one on the oil pump en or center one you can easily fit arse about face with out thinking about it. always looking for them bigger bunches of bannanas |
12th Jul, 2006 at 10:49:41pm
Yes, it really is easy to get the caps round the wrong way, check and double check that they are right.
12th Jul, 2006 at 11:41:13pm
Thanks for the help guys,
12th Jul, 2006 at 11:42:08pm
Good stuff, glad you have got to the bottom of this!
12th Jul, 2006 at 11:43:26pm
i have seen an oversize shell bearing in a pack of new shells ..just one befor now
12th Jul, 2006 at 11:58:50pm
i am closish, but my engine building skills are limited, and having disasters of my own at the moment!! |
13th Jul, 2006 at 12:51:39am
Again thanks for the help. since i last posted i have biult her up ready to go back in tomorrow, so all being well a bit of testing tomorrow and friday, then see you all at Avon. If it breaks... build a much faster one |
13th Jul, 2006 at 08:07:44am
Is it locking up with just the 3 main bearing torqued down?
