| Home > Help Needed / General Tech Chat > avon a non starter for me | |||||||
13th Jul, 2006 at 01:01:20pm
got engine running this morning, i primed the pump and spun over until i got oil pressure
13th Jul, 2006 at 01:14:29pm
dd you bed in the cam at 2000 rpm with the clutch down all the time? if thats the case I would say hi to crankthrust problems. |
13th Jul, 2006 at 01:25:51pm
no mate just put it down once to see if the rattle went Crystal Sound Audio said:
13th Jul, 2006 at 01:42:17pm
okay, thats good:) |
13th Jul, 2006 at 01:50:28pm
a friend had a smokey turbo engine just after a full rebuild. he came round in it and it was sounding fine. we checked the timing and found it at 41deg so reduced it to 15deg and 95% of the smoke stopped. the rest is down to the need to run in the rings.
13th Jul, 2006 at 01:51:43pm
i had a problem with mine smoking at first ,,,it turned out to be thje seals on the choke mechanism leaking and richening it up so it smoked .
![]() 1128 Posts Member #: 142 Post Whore Winchester |
13th Jul, 2006 at 02:52:05pm
i think the next rwyb @ avon isnt till september 30th but there is one at santa pod on 13th august.
13th Jul, 2006 at 02:52:37pm
Bugger mate. I really feel for you.
13th Jul, 2006 at 03:29:07pm
what colour smoke?
AlexF |
13th Jul, 2006 at 03:39:21pm
smoke is mostly white
86 Posts Member #: 631 Advanced Member Thames valley |
13th Jul, 2006 at 03:58:16pm
How about your breathers , they ok?.....excessive oil in the rockers/valves/head area? I know , i know im sorry , it just makes me grin !!!
13th Jul, 2006 at 04:03:53pm
Heres a thought if it was a broken ring.If you pull one of the leads off the spark plugs at a time. if one cylinder is burning oil it should stop.Right! I know , i know im sorry , it just makes me grin !!!
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
13th Jul, 2006 at 04:11:18pm
first off, if the smoke is mainly white it sounds more like head gasket problems and not oil burning problems. All engines smoke initially untill they are run in and it usually takes a while for that to happen (a friends engine didnt stop smoking till after 1200miles).
13th Jul, 2006 at 04:28:36pm
theres no servo and no water in the exhaust
13th Jul, 2006 at 04:52:05pm
does it smoke from the crank case breathers?
13th Jul, 2006 at 05:16:10pm
If you suspect it is water related, then run the engine with the rad cap off so the coolant doesn't pressure up, and see if it still smokes.
13th Jul, 2006 at 05:28:39pm
if the turbo has gone will there be oil in the intercooler pipes?
13th Jul, 2006 at 06:05:41pm
mine smoked like a bitch today until we had the right advance in there. running on 2 cylinders/sometimes 4 and it just chucked smoke out. as soon as the advance was right it disapeared totally.
13th Jul, 2006 at 06:57:07pm
well looks like the headgasket blew on mine
13th Jul, 2006 at 06:58:53pm
there is also no scoring of the bores i take it this shows the rings are ok? Crystal Sound Audio said:
13th Jul, 2006 at 07:04:31pm
Sounds like the rings are OK. High oil pressure shouldn't be enough to blow a headgasket, mine achieves 100psi when its cold at the moment, I need to lower the oil pressure. Bear in mind that the pressure in the cylinders is far far greater than oil pressure.
13th Jul, 2006 at 07:05:13pm
PS did you tighten the studs down using the female hex in the top of them before putting the nuts on?
13th Jul, 2006 at 07:22:35pm
yes mate they were nice and tight in the block
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
13th Jul, 2006 at 09:57:25pm
13th Jul, 2006 at 10:00:27pm
isnt 40 lb ft a bit low for the head bolts ? i cant remember .check for any hairline cracks in the head ,specially from the brass plug to one of the middle chambers .regards good luck ,robert. Edited by robert on 13th Jul, 2006. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
we'll have some beers instead mate
