| Home > Help Needed / General Tech Chat > newbie with questions | |||||||
![]() 28 Posts Member #: 1161 Member Somerset |
19th Jul, 2006 at 07:13:03pm
hi, i'm new to all this mini turbo stuff and have a few questions.
19th Jul, 2006 at 07:39:21pm
The standard bottom end has been used in reliable builds pushing out around 150bhp, as we dont need to rev a turbo a'series to get good bhp, cross drilling and lightening etc is'nt neccessary. Again a standard rebuilt turbo is capable of supplying the boost required but depends on how far you wish to go power wise?
-MINI CLUBMAN 1380 TURBO- |
19th Jul, 2006 at 08:05:07pm
this website link is pretty good for a good concise overview for someone new to the turbo A series
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
19th Jul, 2006 at 08:31:15pm
with regards to your intercooler question i would run one as matter of course even if you keep it stock, at least you are assured that your charge temp is low :) a good intercooler to use is the 2wd cosworth one u can get em on ebay quite easily. i believe a stock mg turbo runs 4psi boost and you get around 90bhp, if it were me and i wasnt looking for serious bannanas (bhp) i would run stock put a cooler on and maybe consider a cross pin diff and sc drops........the diff and the drops are some of the weak points on the engine you mentioned tweaks, you could possibly consider a billet actuator and or phase 2 cam (there will be millions of opinions on this thread)
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
21st Jul, 2006 at 09:17:26pm
On 19/07/2006 20:31:15 my first turbo said:
... and maybe consider a cross pin diff and sc drops........the diff and the drops are some of the weak points on the engine... Richie thanks for the help guys, i dont want sc drops at the moment, but am interested in a new diff whats the best diff to get then? and where from? is the minisport 4 pin diff any good? and would it be a good idea to change the final drive at the same time? whats the best FD to go for? Matt. Edited by GTB on 21st Jul, 2006. |
397 Posts Member #: 694 Senior Member Shropshire |
21st Jul, 2006 at 09:29:37pm
Have read around the site I think there a few pic's of the remains of a minisport 4 pin somewhere on hear.
21st Jul, 2006 at 09:30:48pm
We don't fit s/c drops for the fun of it, for a turbo engine of any state of tune above standard they are bordering on essential to keep the unit reliable.
21st Jul, 2006 at 09:36:26pm
thanks for the heads up on the diff.
21st Jul, 2006 at 09:45:03pm
The standard helical gears by the way they are designed side load the transfer gear casing when the transmission is under load. In a normally aspirated engine this is acceptable up to a point, however the massive torque surge caused by a turbo engine coming on boost side loads these gears to a much larger degree, causing problems. Using straight cuts eliminates this side loading.
21st Jul, 2006 at 09:51:38pm
its the whine that puts me off see,
21st Jul, 2006 at 09:53:49pm
140bhp was just a level that the guys setting the car up at the rolling road felt was safe. How long they last remains to be seen, maybe they'll last forever.
21st Jul, 2006 at 09:59:07pm
how much am i looking at to convert to s/c then?
21st Jul, 2006 at 10:17:54pm
The side-loads on the idlers are actually pretty small.
22nd Jul, 2006 at 02:11:17am
Torringtons are just heavy-duty needle bearings that can be used instead of 'budget' (traditional) ones...
Edited by turbodave16v on 22nd Jul, 2006. On 17th Nov, 2014 Tom Fenton said:
22nd Jul, 2006 at 09:24:58am
i think a much quieter & robust set up would be the stock helical set up with the idler machined out & timkin roller, with stub shaft fitted
