Home > Wanted > stright cut gearbox (or set)
JT
Member #: 637
Hertfordshire
hi
im after a c/r s/c gearbox or a gear set.
im also after a set of 1:1 ratio drop gears.
iv looked on ebay and there doesnt seem to be any at the moment.
needs to be A+, rod change type.
cheers
josh
My build thread..
if you cant get any a good compramise is the minispares clubman gearset
these are SC, they are nearly the same ratio as the metro turbo challange set
mini williams runs this set up and places over 200 hp through them!
iam afraid you may have to raid the bank
JT
Member #: 637
Hertfordshire
yer thats what im worring about mate lol
iv seen a load of gearboxes on ebay but there is no more on there!
iv missed one and it went for £130!!!! im gutted!
i was going to get a challange set but i think it was you that said about them not being made any more so i didnt bother.
do you think a second hand set of ebay or somwere would be ok or is it better to go for a new one from a shop or reliable source?
same as the drop gears.
cheers
josh
My build thread..
i bought a full set of new old stock tran-x from min-its
hoggie said it was one of the nicest gearsets he has installed
might be worth a try
JT
Member #: 637
Hertfordshire
cheers wolfie have they got a website or somthing?
were are they based?
cheers
josh
My build thread..
http://www.min-its.com/
JT
Member #: 637
Hertfordshire
theres a minisport one for sale that i know of, now i know that minisport are usally a big NO NO but if i was to get one that was new, what should i change even if its like new?
or could i just use the gears and buy a re-build kit from minispares with all the good bits in a rebuild it?
would it be worth it if i could get it cheaply do you think?
cheers
josh
My build thread..
What should you change? Any parts made by Minisport. So the gearset, shafts, etc etc........
As stated before, DON'T BOTHER
JT
Member #: 637
Hertfordshire
ok then mate just cheaking as i could get one off ebay thats not to much.
ill just save or wait for a clubman set to come up then i think
cheers
josh
My build thread..
