| Home > General Chat > Who else suffered with lack of grip at Avon? | |||||||
22nd Jul, 2006 at 01:11:26pm
I tried out some new suspension components and settings at Avon this year and was losing 4 tenths in the first 60ft compared to last year and only ran 13.7, with wheelspin into every gear.
I seriously doubt it! |
22nd Jul, 2006 at 07:06:13pm
Mine were 2.2, the best 60fts I've ever had. Grip was not a problem for me. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd Jul, 2006 at 08:24:08pm
I also managed a 2.2...something 60ft in Alex's frog, with bog standard suspension, and Dunlop SP Sport road tyres.
22nd Jul, 2006 at 08:50:21pm
i did suffer to start with but i'm sure as the day came on it got better and better. as some heat got in track. Best 1/4 mile 13.2 seconds @116 mph
1425 Posts Member #: 690 Post Whore Norfolk |
23rd Jul, 2006 at 09:10:36am
Yip 60ft times were down by 0.25 on last year - but only managed 3 runs so no fiddling with suspension to tune in. Was running coil over fronts this year (hi-los and spax front last year)and new coil over rears compared to last year - I'm going to put them on a damper rig to understand the valving in them. Are you still using Protech Paul?
If Carling made Mini engines
23rd Jul, 2006 at 07:39:26pm
acceleration was my biggest problem ..... them dodgems just did not have any go in them Crystal Sound Audio said:
23rd Jul, 2006 at 11:08:31pm
seems like every one apart from me was getting top 60 ft times, well done all, (you bugger!!:)) Best 1/4 mile 13.2 seconds @116 mph
24th Jul, 2006 at 08:25:15am
i did 14.17sec on saturday and 14,22 on Sunday and had a 2.2sec 60ft and had no problems with grip, if anything grip was better than any other year by a long way, but then again i was using A032R tyres not the normal A008's |
24th Jul, 2006 at 01:33:12pm
well it just goes to show paul that all us under powered turbos and vtecs, just had not to bad grip compaired to your N/A, of maybe you need to do better burn outs?? Best 1/4 mile 13.2 seconds @116 mph
24th Jul, 2006 at 05:42:04pm
On 24/07/2006 13:33:12 Miniwilliams said:
well it just goes to show paul that all us under powered turbos and vtecs, just had not to bad grip compaired to your N/A, of maybe you need to do better burn outs?? ![]() I tried rolling burnouts from in the water, tried out of the water, tried no burnout, nothing made any difference though. Odd as usually I do 2.0 or 2.1 60s every time but this year my best was 2.38. The mods I made were new tubular bottom arms and tie bars= lower unsprung weight= better grip supposedly, and new top shock brackets which are 3/4" lower to increase droop which should be better. I think possibly having that extra droop let more weight transfer to the back as the front of the car could lift more. What do you think? Paul I seriously doubt it! |
24th Jul, 2006 at 06:28:09pm
what damper setting on the front ,
24th Jul, 2006 at 08:50:45pm
hell sound like you have tried most things, but don't forget things that "are" meant to work don't always. Best 1/4 mile 13.2 seconds @116 mph
26th Jul, 2006 at 05:20:50pm
On 24/07/2006 18:28:09 fastcarl said:
what damper setting on the front , carl Soft always has worked best for me, but, this time I did hard, soft, medium all sorts....no difference still 4 tenths down. Im doing test and tune at Pod in September Ill try the old shock mounts again. Paul I seriously doubt it! |
27th Jul, 2006 at 06:46:14pm
i used to run as stiff as possible . as you know solid on the rear and full stiff up front [ the dampers that is] no snide sexual comments from you fenton.
Edited by fastcarl on 27th Jul, 2006. |
27th Jul, 2006 at 07:22:57pm
HA HA HA HA HA HA HA!
28th Jul, 2006 at 08:44:37am
So Carl, soft at the back is no good eeh? :) On 13th Jul, 2012 Ben H said:
28th Jul, 2006 at 09:03:02am
I'm suprised that hard on the front works best for you carl (or did when you had one engine) what shocks did you run then carl? Team www.sheepspeed.com Racing
