Home > Help Needed / General Tech Chat > engine lifting
Mini_Andy
Member #: 432
without sounding like a comple plank lol
what is the name of the little hoops that bolt onto the cylider head, that the rope/chain goes though before attatching to the crane.
im getting fed up of wrapping rope around the started, alternator and anythinng around the rear of the engine lol
thanking you :cool:
edit: where can you get them from?
Edited by Mini_Andy on 27th Jul, 2006.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I've used the metal staps that usually hold the plastic engine splash guard in place before - bolted to a couple of head studs.
Alex
AlexF
Lifting eyes?
Although personally I do not like using these as it means slackening off a cyl head stud nut to fit them........
Alex
Brave, brave man *surprised* .......these are only poxy brackets made out of tin if I remember right!!!!!!!!!!!!!!!
Mini_Andy
Member #: 432
On 27/07/2006 15:17:16 Tom Fenton said:
Lifting eyes?
what do you use instead then?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
They are indeed tom!
I have since replaced them with purpose made items.
You can bolt on to studs without removing the nut below oon some studs :)
Alex
AlexF
2" wide nylon webbing strap round the manifold and the down round starter etc as you described!
I am sure the lifting eyes do work OK, just my personal opinion that is all!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
The factory lifted on the rocker cover bolts....
AlexF
Turbo Shed
Member #: 30
Epsom, Surrey
i lift mine out with the rope around the HT lead.
only joking!!!
i think the lifting eyes are called lifting eyes and were available from Rover. or get some of an old vauxhall in the breakers yard
I have a lift, and lifting eyes, but as I don't have a front end, I find it much quicker and easier to get a mate to help me lift it in.
Mini_Andy
Member #: 432
funny you should mention that. when i was looking for a mini not to long ago, we went to southhampton to look at one. The owner was swapping the engine in another mini, with rope around the dizzy and two of the manifold studs *surprised*
we walked away pretty quick (not sure is the engine was comming out, but still lol)
i usually jack it up, get a web strap under the engine mounts then. usually does it a treat.
i would prefer a proper type lift though. it is a lot easier with no front end though.
i nearly always remove the head chuck in a couple of headbolts on the front threads and a bit of chain between, this tilts the engine in the same way the factory eyes did making install and removal easy
i have 1 original rover lifting eye here if someone wants to make any
who, popeye?
Leonard
Member #: 806
Cirencester, Gloucestershire
i have a rough copy i made of the rover lifting jig that uses the rocker studs. then we borrow the forklift from the farm and whip it out. it lifts it just the right angle to clear the diff from the bulkhead, subframe etc
turbochargedstu
Member #: 908
gateshead
old seatbelts work quite well as theyre as strong as a meathead ox on steroids.
not that i know any ox's!
balls to the blower!!!
yeah i've used seatbelts tied in a knot before.
yee haa!! *smiley*
Good stuff though
Yes I must admit to cutting the seatbelts out of a scrap mini to lift its engine out with!
At one time when I worked at a mini specialists we would on average "doom" 3 or 4 cars per week, now that there are not many left on the roads I sometimes do feel a bit guilty, although most of the ones we "doomed" really were well past it........
murderer!
Why howdie. Seat belts all the way!
They do the job nicely, just don't get caught putting them back in your parents car! Lol
turbochargedstu
Member #: 908
gateshead
once you have finished lifting the motor out with the seatbelts you can then use them to whip your girlfriend/wife/mistress on the arse with!!!!
leaves nice webbing marks too!
ha ha, more likely to leave oil/grease marks!
Nick
Member #: 154
Midlands
i've got a pair of the original lifting eyes sat in me garage if you want em? swap you for a sticker..lol
Mini_Andy
Member #: 432
send em my way lol
email me with your request
info@vinyl-graffix.co.uk
andeh
Member #: 97
Near Daventry, midlands
personally i use nylon rope and tie it tightly around the head, udner the thermostat lump under the manifold and around the lump at the other end. Tie it between the middle two plugs and lift at that point. The whole thing tightens up and lifts the engine out at the correct angle.
Method came from peter calver iirc
