Home > Help Needed / General Tech Chat > fan help
run the car up this evening and everything seemed fine, went inside for something to eat and the ketttle to top water up as i ran car up without pressuring system in order to get air locks out
started car again instantly there was a grating noise i switched off and found 4 blades from the fan on the floor, the fan seems to have developed a curve and hit the ultimate engine steady
now last year the same happened and i wonder if the spacer on the water pump was the wrong thickness its about 5mm should it be thicker than this?
i was going to merlin in the morning to buy an electric fan as a backup is it worth junking the normal fan and just running the electric one?
i dont run a mechanical fan, just an electric one thats on all the time
is the fan fouling on the breather?
no mate
it hits the overhang of the ultimate engine steady but it only did this after i had run the car up for 5 mins to make sure there was no air locks ........ its very odd
Have you checked that the water pump bushes haven't collapsed, allowing the fan to foul things?
Lucky a blade didn't go through your rad!
the pumps brand new mate
i will bin the mechanical jobbie then and run an electric tripac fan, i should not have any issues there should i?
jimmy
Member #: 829
essex
I had one that was fitted the wrong way round and on a hard pull away the fan was hitting the hose clip on the water pump and that had the spare fitted too
1293 Turbo mini
i run only a small leccy fan on mine .
Turbo Shed
Member #: 30
Epsom, Surrey
the fan should run in the couling and thats a couple of inch's away from the head steady.
when you fitted the fan spacer, you did fit it between the fan and pump?
any way the fan only creates drag and an electric one will work better
jimmy
Member #: 829
essex
I run both to be safe but it`s up to you i use the electric one when i`m in trafic
1293 Turbo mini
Scruffy
Member #: 328
Seaford Rise, South Australia
I have never found an electric one on its own to be as efficient and needed extra cooling when relying on just leccy one
On 5th Sep, 2011 Vegard said:
JT
Member #: 637
Hertfordshire
im going to bolt a electric fan on the outside of the rad so its mm's away from the rad like on moddern cars.
but ill have it so it starts when the water reaches 88 degrees and wont turn off untill its below even once the cars off (like on moddern cars).
ill just ditch the mechanical one, this should also help with it all getting up to temperture etc.
cheers
josh
My build thread..
this is what im doing
and it has no problems at all
