| Home > For Sale > metro vents with 4 pot capliers | |||||||
1300 Posts Member #: 829 Post Whore essex |
3rd Aug, 2006 at 12:36:28am
one pair of vented discs and 4 pots capilers 1293 Turbo mini
3rd Aug, 2006 at 07:45:49am
Two or three piece calipers? On 13th Jul, 2012 Ben H said:
3rd Aug, 2006 at 07:48:19am
How did I know that question was coming from Vegard!
3rd Aug, 2006 at 07:51:54am
Because you know my friend, that I'm after some three piece ones On 13th Jul, 2012 Ben H said:
3rd Aug, 2006 at 12:04:21pm
Pretty sure if they are vented they will be 3 piece. On 21st Jan, 2011 fastcarl said:
3rd Aug, 2006 at 01:53:50pm
Vegard, I am assuming you want three piece ones so you can remove the spacer and run them on non-vented discs, could you not hold a 2-piece caliper half in a milling machine and mill down the caliper half "lugs" to reduce the caliper "bridge" distance to achieve the same thing?
3rd Aug, 2006 at 02:27:06pm
Ah, great thinking. That might work. I would have to make a recess for the seal, but nevertheless... On 13th Jul, 2012 Ben H said:
3rd Aug, 2006 at 03:22:54pm
Would only require the lugs milling down and then a small counterbore machining for the seal to locate in, you could just measure the seal recess diameter and depth before machining and replicate it on the new faced surface......
