Home > A-Series EFI / Injection > 5th Injector on a 7 Port
MaltaMini
Member #: 510
Malta
Hi people, was just thinking on the lines of the Jap tuning boys with Starlet GTs and Glanzas...
I'm thinking of one injector per inlet, just like the Glanza, but then I was thinking of a bigger injector in the plenum, which will come in on boost.
What do you guys think?
Can Megasquirt handle this?
I donated, but somehow didn't get the label! :(
megasquirt can do staged injection, so yes,
i think it'd be better to have 8 injectors though if you go this route.
MaltaMini
Member #: 510
Malta
Cheers guys!
I'll just fit a dummy 5th injector as psychological warfare with the Cossie guys! :)
My worry with using bigger injectors is - are they sensitive enough at low settings? This is a road-legal car, and therefore the engine cannot go extra rich in traffic. That's why I wanted to split it up into 4+1.
Besides, if I let my girlfriend drive the car, I can always disconnect No. 5 *wink*
disconecting the 5th injector sounds like a good way of running lean.....
