| Home > General Chat > Gearbox ideal spec for hand driving around the bend. | |||||||
138 Posts Member #: 138 Advanced Member |
9th Aug, 2006 at 07:27:26pm
i would like to build a gearbox to spec that are okay with hard cornering (well, its mini, and i happen to live in a city of 300+ roundabouts) and i would like to do some track day.
9th Aug, 2006 at 07:38:39pm
You won't be able to use an LSD with a 3.2 as even a 3.7 & 3.44 need machining to fit and 3.444 is the lowest you can go.
On 5th Sep, 2011 Vegard said:
9th Aug, 2006 at 08:29:49pm
search for lsd, you may change your mind, i'd personally just go with a crosspin diff. |
76 Posts Member #: 1038 Advanced Member |
9th Aug, 2006 at 09:29:13pm
Try a quaife ATB diff, very user friendly but work extremely well in a road / track car.
9th Aug, 2006 at 09:30:22pm
On 09/08/2006 21:29:13 danwebster said:
Try a quaife ATB diff, very user friendly but work extremely well in a road / track car. Yes I will second that comment.
9th Aug, 2006 at 09:46:17pm
the FD sounds right to me
10th Aug, 2006 at 03:27:18pm
On 09/08/2006 21:46:17 benross said:
the FD sounds right to me Agree but you will not get a cwp for an LSD in that ratio as it will not fit as the o/d for the lsd is too big to fit inside a crownwheel for a 3.2 ratio! Show me a link for an available part and I will eat my words! On 5th Sep, 2011 Vegard said:
10th Aug, 2006 at 04:14:42pm
If you're willing to machine a LSD and Crownwheel, then crack on...
10th Aug, 2006 at 07:20:32pm
On 10/08/2006 16:14:42 TurboDave said:
If you're willing to machine a LSD and Crownwheel, then crack on... Harry commented on how much of a pain this was, due to the VERY hard surfaces that had to be machined through.... it wasn't just a hard case-depth, but a high-grade material alltogether. http://www.turbominis.co.uk/index.php?p=14&album=26 Some fantastic machining but some very thin bits of metal between the teeth and where the lsd bolts to the crownwheel?? On 5th Sep, 2011 Vegard said:
10th Aug, 2006 at 07:45:06pm
Totally agree.
10th Aug, 2006 at 07:48:40pm
Incidentally, KAD have started making some very high spec CWP's which are also priced reasonably. If you have problems with eating pinions like me they're worth considering. |
11th Aug, 2006 at 09:02:31am
On 10/08/2006 19:48:40 danwebster said:
Incidentally, KAD have started making some very high spec CWP's which are also priced reasonably. If you have problems with eating pinions like me they're worth considering. 4:1 & 4:3 only though On 5th Sep, 2011 Vegard said:
11th Aug, 2006 at 12:00:46pm
They'll be doing shorter and longer soon though apparently. |
