| Home > Help Needed / General Tech Chat > Piston Cooling Nozzles... | |||||||
12 Posts Member #: 234 Member |
13th Apr, 2004 at 12:43:11am
Could someone tell me what year model Zetec nozzles are used. I've called Ford and they told me there was two different part numbers.... |
13th Apr, 2004 at 10:25:34am
I have a picture at home of the nozzle sat on the packet showing the part #.
15th Apr, 2004 at 09:36:15am
Thank you very muchley....!! |
15th Apr, 2004 at 10:58:07am
(img/http://mini.lyons-it.co.uk/davecoxon/Ford_Zetec_Jet.jpg img) Edited by turbodave16v on 17th Apr, 2004. On 17th Nov, 2014 Tom Fenton said:
15th Apr, 2004 at 06:35:51pm
Here you go mate ..........
17th Apr, 2004 at 09:51:09am
17th Apr, 2004 at 09:51:35am
17th Apr, 2004 at 06:46:18pm
Dave - Yours are a different part no to the ones Mike used, but they look the same.............
263 Posts Member #: 115 Senior Member Austria, near Vienna |
17th Apr, 2004 at 06:52:38pm
Dave, do the squirters have a built in valve which starts to open at a predeterminated pressure - or do they squirt oil all the time? The Turbo oil pumps cope with the higher oil demand?
Bimmer Twinky headed and turboed A-Series:
18th Apr, 2004 at 11:41:09am
Harry, there is an integral valve - it opens at around 15psi i recall...
19th Apr, 2004 at 09:43:41am
Do they need a seal of any kind ?
![]() 265 Posts Member #: 68 Senior Member Coventry |
19th Apr, 2004 at 10:48:07am
how are these fitted to the block exactly? Sooperdooperturbocooperexpertengineering! |
19th Apr, 2004 at 03:22:16pm
Were the pistons different in the cooper block?
AlexF |
19th Apr, 2004 at 03:53:49pm
pistons were no different, but the block visibly was... Basically the height from the deck to bottom of the bore was around 3mm longer on the later block than the earlier ones...
22nd Apr, 2004 at 12:31:26pm
how much are they? Sooperdooperturbocooperexpertengineering! |
22nd Apr, 2004 at 12:52:43pm
dont worry, i found em, ?5.58 each. Sooperdooperturbocooperexpertengineering! |
