Home > Wanted > Tapered Hub washer, disc brakes
After a tapered washer that goes behind the hub nut if anybody has one, kind of desperate as coming back from york the van sheared the driveshaft nut split pin and it looks this is the reason why! When the S brakes had been fitted by the previous owner it appears they neglected to fit one!
Need to get the van back on the road asap.
Can pay via paypal to speed things up
its for S brakes but i assume that the washer is the same?
Many thanks
Iain
giallofly
Member #: 164
The Stig..
Newport Pagnell
i have one..i o u a vacume pipe so i'll post it up and call it quits.
I have your no and will call you 2 mrow..
Mr headgasket.
Forgot about that vacuum pipe!!
Got a washer on its way mate so no worries! Ive got plenty of vacuum pipes kicking about, doesnt make alot of difference to my motor, runs fine without it!! Probably better!
Figured out what the problem with the head gasket is?
giallofly
Member #: 164
The Stig..
Newport Pagnell
it is unlikely to be the gasket(s) as they both went in the same place..i fear it is the block even though it was refurbed in my ?1000 rebuild?...will let you know..taking a week off with that bloody machine!..decorating and dirt bikes this week!
Not good news really, take it somebodies for the high jump!!
