Home > General Chat > setting up suspension!?
JT
Member #: 637
Hertfordshire
hi
iv just fited a set of adjustable heavy duty tie rods from minisapres.
iv set them so there the same length as the standerd ones if just taken off (they are bent).
now when i go right it feels ok (a bit heavy maybe) but when i go left it feels to light!
when i brake it trys to go left!!
i need to sort it out but im not sure how.
would i be better off fitting negative cambre hi los adjustable shockes etc then taking it somewere to set it all up or just try setting it up one at a time?
do you know any were that will set them up well in my area? (im in north hertfordshire/bedfordshire area.
cheers
josh
My build thread..
Make sure that your tie bars are set equally for a start.
Scruffy
Member #: 328
Seaford Rise, South Australia
You have a PM
On 5th Sep, 2011 Vegard said:
JT
Member #: 637
Hertfordshire
yer i was very carfull to make sure there both equal, but thinking about it it was doing it a bit before i fitted them its just that now the proplem is now exadurated (sp??)
ill get it all sorted by a proffesonal at some point *wink*
My build thread..
JT
Member #: 637
Hertfordshire
has any one used the evolution AGX adjustable dampers from mini spares?
they sound good but was wondering if anyone else has tried them?
are they any good?
would you recomend them?
cheers
josh
My build thread..
t3gav
Member #: 229
Gavin@minispares.com
kent
i would use the kayaba gas adjusts, heard really good feedback from them and KD has them on his sportspack.
yes i've just chucked them on mine, with the 1.5 neg camber arms, so i guess mine need setting up to.
