| Home > Wanted > a-series metro hubs | |||||||
12th Aug, 2006 at 12:57:51am
know a few of you gents have broken one or 2 metro's for engines and brakes, so hopefully there are some metro hub's lying around. i specifically need the a-series metro hubs and steering arms. dont need the brakes or CV's or owt.
12th Aug, 2006 at 11:52:30am
I've got two sets in Norway. They're yours for free :) I could check postage if you'd like. If not, I'm coming over late october. On 13th Jul, 2012 Ben H said:
12th Aug, 2006 at 05:17:59pm
please do mate :) .. only need one set tbo. (wana see if torque steer/tramlining is reduced useing the metro hubs as i believe they have a larger kpi and longer steering arms makign torque steer easier to controll. jsut a hunch but really want to try it out.
12th Aug, 2006 at 05:34:32pm
I think you'll be best off useing the mini steering arms on metro hubs, otherwise the ackerman angles will be really wrong.
12th Aug, 2006 at 08:26:19pm
well i want the setup so i can experiment, mini Vs metro hubs and arms. Im running 195/45/13's on 7x13" rims.
13th Aug, 2006 at 01:22:04pm
By all means try it but i'm almost sure the mini Steering arms will be far closer to what you need. IIRC Ackeman is linked to the wheelbase and width of the track.
20th Aug, 2006 at 03:37:34pm
bumpio, still after these :) turbo 16v k-series 11.9@118.9 :)
21st Aug, 2006 at 08:06:54am
I'll try to find postage for you. On 13th Jul, 2012 Ben H said:
![]() 164 Posts Member #: 206 Advanced Member Milton Keynes |
24th Aug, 2006 at 08:52:48am
I think I've got a spare set with drive shafts etc 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
