Home > Help Needed / General Tech Chat > Inlet manifold confusion
confusednewowner
Member #: 854
Fareham, Hampshire
Why is my inlet manifold different to this one on ebay? Have they put a n/a manifold onto the turbo carb?
http://cgi.ebay.co.uk/MINI-TURBO-METRO-ERA...1QQcmdZViewItem
http://s63.photobucket.com/albums/h121/mho...mgAnch=imgAnch1
As you can see the piping is slightly different and could someone tell me what the item that is circled in red does (excuse my stupidity but I do not yet have a metro turbo haynes manual)
Also what does the piping coming off the inlet manifold do?
vrooom
Member #: 138
That could be a servo take off bolt to help servo assisted brakes.....
nogin
Member #: 487
westbury, wiltshire
they are the same due to the casting number, pipes have been bent for some reason and the bit where the red circle goes is todo with the servo vacume take off
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
JT
Member #: 637
Hertfordshire
what would you use it for if you dont have servo assisted brakes then?
turbo gauge or and dump valve?
if so could you use the same hole for both by fitting a T piece on it?
or would you end up with a false reading on your turbo gauge? and a dodgy DV?
cheers
josh
My build thread..
Can't see ebay in work, but the photobucket manifold is standard metro turbo with the water heater piped still on.
I use servo takeoff for my dumpvalve and boost gauge and MS signals.
Wil
JT
Member #: 637
Hertfordshire
wil how do you get 3 off of one servo take off?
a 3 way pipe sort of thing?
could you send me a pic please just to see how youv done it.
cheers
josh
My build thread..
confusednewowner
Member #: 854
Fareham, Hampshire
Or post a pic on the forum and I am also interested in seeing this.
Thanks
Well they all come off the same point on the manifold but it's nothing clever, just 2 T-pieces. One at the manifold then one in the line to the boost gauge.
